PVC/ABS Clogs
  • PVC/ABS Clogs
    General question. What percentage of drain clogs do you encounter are PVC/ABS?
    Re: PVC/ABS Clogs
    about 15%
      Re: PVC/ABS Clogs
      Originally posted by Drain Medic View Post
      about 15%
      10-15%
      and when they do clog, it's typically because of poor installation/ flat or abuse with the kitchen sink.
      the great thing with plastic is when you clean it or jet it, it's pretty much like new. can't say that about cast, gal, or even copper dwv.
        Re: PVC/ABS Clogs
        15% sounds about right and there usually easy
          Re: PVC/ABS Clogs
          Interesting. Sounds like if the majority of the old were replaced the drain cleaning business would decline dramatically. Be hard to make ends meet.
            Re: PVC/ABS Clogs
            10-15%
            Your absolutely right. I love getting clogs in PVC...specially kitchen sinks
              Re: PVC/ABS Clogs
              Not really, cause usually when you see PVC, its the hacks or handyman that installed it. So its either sagged, backpitched, or just flat out installed wrong. I love seeing pvc clogs, cause i know its going to be an easy clean
                Re: PVC/ABS Clogs
                Not really? I've seen the hack work also. But 3 pros just stated 10%-15%. That means if the non PVC/ABS were replaced then we would lose 85%-90% of current drain cleaning business. Right? I know there is TONS of the old but I was just thinking in theory about the future.
                  Re: PVC/ABS Clogs
                  Sure, possibly in the future. But ya really, either way your going to get clogs. If everything was PVC, and the average person thinks that pipe is superpipe, whats going to happen then. lumbdog:
                  Biggest problems i see with PVC main lines are sagging, not strapped correctly or at all. The other is breakages at the foundation walls.
                  Either way you have it, your going to get blockages. But, if in 100yrs from now everything is PVC, im good with that
                    Re: PVC/ABS Clogs
                    about 5%
                      Re: PVC/ABS Clogs
                      I guess it depends on your service area as we were closer to 50%.
                        Re: PVC/ABS Clogs
                        about 20%......here they are building these houses so fast that i guess they not turning the plastic pipe 1/4 turn to spread the solvent cement..here i get alot of off-sets when unstopping pvc.......its usually an easy unstop and mostly you can do a spot reair very easily also..
                          Re: PVC/ABS Clogs
                          I didn't quite understand this. Could you explain a little better please.
                            Re: PVC/ABS Clogs
                            In my town, 99% of the buildings have ABS drains. I think I can count on one hand the number of drains I snaked that were cast iron or galvanized. Also, there are only a handful of buildings left out here that were built before 1970.
                              Re: PVC/ABS Clogs
                              There will always be a job when you will go to a place where nobody else will go if you know what I mean
                              Seattle Drain Service
