Time?
  • Time?
    What's your average time for cleaning a residential drain? Commercial drain?
    Re: Time?
    What type of drain boss?
    Proud To Be Union!!
      Re: Time?
      Just looking for a general average. I know a 10" main would be much different than a 2" floor drain. Grease, towels, etc. would make a difference. But I was just trying to learn about the average draincleaners day.
        Re: Time?
        Less than 2 hours even on a roof, this is for 4" and smaller.
          Re: Time?
          rollup in drive to driving away;
          kitchen sink, tub, shower, floor drain - 45 min
          auger toilet - 20 min
          pull toilet and remove object from base - 45 min
          snake 3" or 4" toilet line from pulled toilet, easy clog, close - 1hr, interior c/o - 45min
          jet 4" sevice or grease trap inlet and outlet, good access from exterior c/o or trap, no water management issues - 1hr
          jet frozen service - varies wildly depending on length and hardness of ice, quality of access, water management - 1-6hr
          park garage floor drain system full of sand - again depends on how much sand, access, length and number of runs - 1hr to multiday
          poor access, very long lines (200'+) full of roots, objects or concrete in line, broken lines, etc take longer. add 20 min to camera, longer to make a video
            Re: Time?
            snake and camera usually just under 2hrs if i'm taking my time.
            Average distance to main around 70'.
            Clean out always in basement. We don't have outside c/o's here.
              Re: Time?
              but there is always the one that throws the curve; I took 2 1/2 hours on a kitchen sink a couple days ago; back to back in a wierd way 10' from sinks thru 2 90's and a 45 each side with next door unit, very hard to make the drop, had to camera in one unit and watch while working eqiupment in from other
                Re: Time?
                so if it is backed up all up in the house, how do you catch it when you open it up?
                  Re: Time?
                  the "average" time is is 10-15 minutes for Spartan machine WITH clean-out. Mini-Jetting add another 30-40 minutes..Trailor Jetter about an hour for ONE clean-out.....Camera,loacte and Repair..............PRICELESS!!!!........lol....th ought i'd throw that in!!
                    Re: Time?
                    What do you mean, catch the clog?
                      Re: Time?
                      Pop the cleanout, everything comes out
                        Re: Time?
                        We always budgeted an hour for drain cleaning unless there was something unusual about it.
                          Re: Time?
                          It really depends. Are you talking time just on the job or job & drive time. I cannot drive to a location, talk with customer, diagnose the problem, lay out mats, clean the drain and clean-up in less than one hour. We schedule two hours, one guy.
                          I try to clean the drain the best I can. I just don't ram rod it and pull it out. I will also look at their plumbing for any obvious problems and make recommendations. If that means getting into a wet crawl space, I'll do it.
                          I look at drain cleaning as a service, not production.
                          Hope this helps.
                            Re: Time?
                            I agree with Tyman pretty much.
                            By the time I talk with the customer, brain storm real quick how to lay myself out, bringing the machine in, answering the phone telling the boss how far I've gotten so far to plan the next call, clearing the drain, cleaning up my mess, and usually the majority of, if not all of the mess caused by the stoppage, putting my truck back together, double checking the job, and checking my tool bags to make sure I have all my tools in under an hour would be tough.
                            Proud To Be Union!!
                              Re: Time?
                              well it takes me about 5 minutes to clean the toilet, can that be considered as a drain
                              §m€llŸ™
