Rootx-uses
  • Rootx-uses
    Guys
    Just a quick question on Rootx now that is available in Australia has any one used down it a trap.
    I have watched rootx on how to video but was wondering if real plumbers use it a different way as they only recommend toilet or clean outs.
    Traps in Australia have a water seal stopping gases coming out and are approx from 3ft to 6ft down in ground.They are also called ORG (overflow relief gullies) so when sewer backs up from main it doesnt come in to house.
    Any suggestions as I think I am one of the first to use in my town.
    BTW keep up the discussions as I am a avid reader of the K60 vs 1500 also the forum is my second most visited site after MLB.com.
    Regards
    Greg
    Re: Rootx-uses
    greg, that would be the k-60 vs. k-7500
    root-x down a trap can work if first plunge/ pump out the trap dry.
    if you attempt to pour it into standing water, you will get foamed
    mix up the 2 powders into 1. drop it into the trap dry. then seal the top of the pipe with a test plug and then flush the toilet 1 or 2 times depending on the amount of root-x you have installed.
    2# = 50' of 4'' pipe.
    1kg = 16 meters of 100mm pipe
      Re: Rootx-uses
      Duh
      As you can see Rick I am new at the game .You knew what I meant keep up the good work.
      Regards
      Greg
        Re: Rootx-uses
        rootx is a pretty good product, although I have noticed that the product does not flow down the line very well on long runs.
          Re: Rootx-uses
          Hi Greg
          I have heard a lot about RootX but where do you buy it do plumbing suppliers sell it.
          Tony
            Re: Rootx-uses
            www.seca.com.au in sydney are australias only supplier.
            Cheers
              Re: Rootx-uses
              Cheers
              Thanks Greg
              Tony
                Re: Rootx-uses
                Greg,
                We've discussed these traps/orgs before re cameraing thru them. I would like to see a diagram showing distances to main and house, access points, shape of the trap, etc. for a typical installation. As I envision what you describe I don't see how they prevent a backup into house from the main, so I must be missing something.
                My experiences with rootx are good, but here I don't have your traps. I've found it advisable to keep a plunger close by when applying rootx through a toilet just in case I put too much in at once. Also I once put a 4lb jug in the toilet flange as I had the stool off anyway, then set it and flushed and got a geyser. You might have to experiment a bit to get a method that works for you... do it; I've found rootx to be a good product.
                  Re: Rootx-uses
                  i've always used a plunger into a somewhat dry toilet and plunged it down as it foamed. maybe just 1# at a time. 4# is ruff at 1 time into a toilet. a c/o is best for 4#.
                    Re: Rootx-uses
                    Originally posted by Ace Sewer View Post
                    Greg,
                    Yes you do have traps just look into any toilet pan and you will see water at the bottom of it which stops the smell from the sewerage pipe entering your house this is called a trap in Aus either an S trap where the sewer pipe connection is through the floor or a P trap where the sewerage connection is through the wall and is 4" (100mm)
                    Tony
                      Re: Rootx-uses
                      Greg,
                      Overflow Releif Gully provides an open ended branch through which sewer can overflow in case of a blockage.
                      A typical installation has an ORG as the only fixture on the most downstream branch off the house lateral(I think thats your term for it).
                      Any blockage downstream of this branch will overflow at the gully, the top of which is miminum of 150mm or 6 inch below the finished floor height in the house.
                      I know a picture speaks a thousand words, i'll work on it.
