removing scale in cast iron
  • removing scale in cast iron
    What are some of you using to remove heavy scale from cast iron?
    I have nearly a 1000 feet of 4 inch cast that is scaled up bad. I have to access the lines through 4 inch clean outs so I can't fit the Warthog in. It would be overkill anyway.
    I am considering purchasing a 3/8 root rat but I thought I would run it by you all to see what ideas you have for this. The work is being done in a senior center and replacing the pipe is out of the question at this point.
    Just so you know, it is extremely thick in some areas and we have already removed 6 five gallon buckets of scale from the newer part of the building that has the least amount of build up in it. The pipe seems to be in good shape aside from the scale. Any help would be great!
    www.firstresponsedrain.com
    Re: removing scale in cast iron
    http://www.ridgidforum.com/forum/showthread.php?t=17049
    What's the single furthest run and what size line is it? Have you thought about a 3/8" warthog or a chain knocker?
      i have had good luck with a chain knocker 1-1/4 inch cable and my k1500.
        I remember the thread that you pasted above. I guess i was thinking that since i have a jetter i should utilize it in this situation. I have looked into the Spartan 34 descaler and was told that it would not work off of the 30 gpm jet that i have even with the 3/8 lateral line i have.
        The longest length is 100 ft, 4 inch.
        I know little about chain knockers. Will this be the answer? Where do I find one for my Spartan 1065?
        I have considered the 3/8 Warthog, but thought that flailing chains would be more effective. Like I said before, I did use a 3/4 rotating nozzle at 3000 psi and it still did nothing to the thick scale.
        If that did'nt do it than I don't want to waste my money on the Spartan descaler. This is build up like I have never seen before.
          Why wouldnt a Warthog fit thru a 4in cleanout??? What size do you have??
            Please post pics of this, sounds interesting.
              If the 3/8 Warthog cant go through a 4inch line, it may need to be replaced...did you camera it?...it may be more than scale and just collapsing
                Here is the 3/4 Warthog that I have. You can also see the nozzle kit that I used to flush the lighter debris after descaling with the rotating nozzle on the right side of the kit shown.
                I did camera the line. It is not collapsed any where in the system.
                  the warthog is 100 times better than your other smaller rotating nozzle. that one rotates so quick that it really looses most of it's impact on the pipe.
                  i would think a chain knocker or root rat style head would be your best bet.
                  of course a reverse c/o is a much better way to flush out the debris. otherwise you're pulling it back to you. also 30 gpm is going to blow all sorts of toilets with that much flow.
                  i would probably look into a reverse c/o and a chain knocker on a 1.25'' cable first. 30 gpm is a lot for 4''.
                    Sorry, I should been more specific, pictures of the scale build up from the see snake, job pics
                      I always want to jet, cable if I must. If you decide to cable, run a lot of water as you do to wash what you knock loose down and out.
                      You've got a bigger Warthog; they make one for 3/8" hose that will fit, about $700 the last time I bought one... it is a great nozzle for 3" and 4" and is worth having. You will do best if you can work up the lines from below and pull the scale down.
