toilet
  • toilet
    so you get a call on a clogged toilet,you get there use 6' auger still won't drain pull bowl do any of guys charge more for pulling bowl?
    Re: toilet
    What is the policy of your the company in this situation?
      Re: toilet
      You should charge more for the framing hammer usage.
        Re: toilet
        Aboslutely, time is money.
        Of course that shouldve been explained with your diagnosis.
        I simply say, " Ill try my Auger, and if that works, it will X amount of dollars, but, if the clog is not in the toilet, then im going to have to remove the toilet and cable out the line.", Then tell them, if the Auger doesnt work, i wont charge you for the Auger, but i this is the price to remove the toilet, cable the line, new bowl wax, new bolts, new water supply. No problemo
          Re: toilet
          not to start a ruckuss but as a T&M man if it takes longer it costs more.
          i'd much rather have 3-4 jobs at 1 1/2 Hrs each than one 4 hour job.
          i explain to the customer what i'm going to do and why. and if i need to go to plab B then i explain that to them also. most don't have an issue IF they know what's going on
          steve
            Re: toilet
            I wonder what a fair charge would be to auger a toilet ? Sometimes it's just a simple job and takes a few seconds.
              Re: toilet
              I charge $55.00 to use the sh!@ stick. if it doesn't do the trick, and I have to pop the toilet then I don't charge for the stick.
              basically its a half hour charge.
              Sent From The StoolBus
              www.appletondrainandsewer.com
              Appleton WI, 54915
              1-920-284-7471
                Re: toilet
                I charge for just a service call if I only have to plunger or auger. If I pull the the toilet the price goes up.
                  Re: toilet
                  Ditto.
                    Re: toilet
                    It may take you a few seconds, but they still called you because they couldnt fix it, right??
                    Its took you 25 mins to a half hour to get there.
                    Its time on your schedule.
                      Re: toilet
                      Being flat rate, I have a task for attempting to clean the toilet with an auger. I have a higher charge for having to pull it. It never hurts to try a plunger first.
                      Pull don't push. Push plunger down slowly, pull back with force.
                      I also carry a hand mirror and a flashlight so that I can see into the trap. (Seriously considering a itty bitty see snake.)
                      As to only taking a few minutes, I've spent a lot more than just a few minutes with an auger. Even if it only takes a few minutes, the company must be paid for sending you out. A lot of people are under the impression that, since they have to drive to work without being paid for it, you do too.
                        Re: toilet
                        how much extra too pull toilet if you can't do it with auger?
                          Re: toilet
                          I give a flat rate to clear a toilet of $70 but if it's a easy fix with the auger then it's $63. If the auger doesn't work and I have to pull the toilet then the total cost would be $80.
                            Re: toilet
                            auger is 80.00, same as a service call for me.
                            stoppage in closet bend....priceless.
                            Robert
                              Re: toilet
                              $68.00.
                              Have you seen the cost of a good auger lately?
                              There's no way I'd quote a pull and reset on the front end. Too many ifs....
