My autofeed won't reverse anymore
  • My autofeed won't reverse anymore
    The Auto feed on my 3/4 cable drum machine won't auto feed in reverse anymore, goes great in forward. All the rollers seem fine and the cable doesn't look flat. Any suggestions? Thanks
    Bryce
    Seattle Drain Service
    Re: My autofeed won't reverse anymore
    Never mind one seized roller, great one of those days roller seized then one of my seesnakes has a broken plastic piece around by the counter and by the interconnect cord. I hate working then comming home and working on the tools but oh well.
    Bryce
      I dont know how much you use your`s but I replace my feeder bearing about every 3 to 4 months
        How do you pull out the knurled nut below the feed knob so you can replace that ball bearing? I understand it is pressed in.
          my auto feed never has broken on my k-60
          tomorrow i have 19 drains to snake and jet. the other day i did 22 of them without a hitch and the auto feed worked great. although my right hand is a little bigger
          keep the bearings clean and dry. don't over tighten the feed knob and always help the cable in and out. change all 3 feed bearings. not just the one.
            and my jaws never ware out on my k-7500
            I thought you were a plumber not a sewer rat??????
              I'm not sure what machine you have but, if a k750, just remove the snap ring then tighten down the tension knob on the cable. If the drive is already off the machine, use a chisel handle or something of equal size to the cable in it's place. As you push the bearing down on the cable it will build up enough pressure to push the bearing holder up out of the drive body.
                Thanks droopy I will give that a try.
