How are you cleaning main lines?!
  • How are you cleaning main lines?!
    I have forever figured out weather its a 4" main all the way
    or a 4 then into a 6" and just go with that sized double blades.
    Only on real bad root jobs I'll drop down to a single then go back with doubles.If I can't get through.
    BUT..
    The other day doing a newer sewer, I got a cable stuck (And good!)
    this was 4" pvc so i ran 4" doubles slightly compressed together and went out of a 90 that had busted because part of the line had settled 3-4".
    So,,,Are you running out with singles first then going back...?
    I have been given advice to run a singe or double 2" through EVERYTHING first.
    Sounds like bad advice in a rootbound main.
    Bear with bad spelling and grammatical errors. It's 4a.m. and I just got back from a root bound emergency.Big nasty thick roots. Pulled back a 5 gal. bucket worth.
    The 7500 and Mytana red flex cable and double 6" blades did a fine job as always.
    Re: How are you cleaning main lines?!
    i always start off with the large blades and see if i can power through. if the spiral root saw doesn't get through, i'll scale down and use a smaller root saw.
    i also look at the color and condition of my cutters to see if i'm cutting or grinding a joint, dirt?
    the last thing i want to do is drill a hole into the stoppage to let the water/ waste out. drilling with an auger can get you stuck. it can drill a small hole, grab big roots and not be able to pull back through the small hole you bored.
    fortunately i have a good track record of my customers mains and i know the bad few. the first timers or referrals i typically ask questions and get a time line.
    if i camera a line, then i have the footage and distances of the bad parts.
    i can easily work my sectional cable to the exact footage and home in on the problems. the drum cable is hard to maintain my footage marks.
    i've tried paint, shrink tubing and nothing holds up. sectional has a built in mark at every section.
    i will use a 4x6'' when i have a good picture of the system and max distance. those cutters are designed to be a finishing cutter and not a primary cutter. the spring has been lost/ damaged in the past and without a spring, they're useless.
    now with a jetter/ trailer with warthog, i can conquer the world
      On most 4" main line I`ll start with a 3" double blade. If it wont make it through the clog I`ll pull out and go with an auger to open the line and follow up with a double blade. The only time I will run a double blade the same size as the main line is when I know there are no broken joints to get stuck in.
        Rick I fully agree with the jetter and warthog but not every basement here is easily accessible with the jetter hose over the white carpet!
          I start with a 3" single, then move on to a 3" full blade.
          I then run a 4 to 6 expandable at an additional cost with a chemical treatment.
          Robert
            I go the opposite. I start with a straight auger and then move to a bigger blade later.
              I start with a 3" spiral root saw. If I camera and know the pipe is in good shape I'll finish with a 4" spiral root saw.
                if i go into a line typically 4-5" mains in my area,i always go with the auger first on a sectional machine...if it bounds up i keep working it till theres no more problems ...then ill run a spiral saw to finish
                  What's so bad about that?
                    I want all that head pressure behind the stoppage, I always fill my mains up before I clear them.
                    Robert
                      Rather than just poke a hole in the middle, he likes to know it has pushed through to the city connection. He can typically tell when the stoppage has cleared completely.
                      If you just poke a hole, it is a temporary fix until it plugs again. Which will be sooner than if the stoppage was cleared properly.
                      I love my plumber
                      "My Hero"
                      Welcome, Phoebe Jacqueline!
                        Thanks Joey but I think this post shows that you two need something else to talk about. I guess Rick has told you this a couple times.
                          Nope. Gone to work with him enough to know The sad thing is that I had to explain it to you
                          I love my plumber
                          "My Hero"
                            You say potato, I say potatoe. I always use a full size cutting auger as my final pass. Me and Rick achieve the same results, just go about it differently.
                              Me too, water's always running while the cleaning the line.
