Guide Hoses
  • Guide Hoses
    Guys,
    I am wondering if I can get some opinions on front guide hoses.
    Do you use one?
    If your machine came with a front guide hose, would you use it?
    Anyother feedback will be appreciated!
    Thanks Again
    Renee
    Renee
    Product Manager
    RIDGID Drain Cleaning
    Re: Guide Hoses
    Originally posted by Renee View Post
    Guys,
    Do you use one?
    Thanks Again
    Renee
    I have a front guide hose for my K-50 and used it a lot in commercial kitchens but not much anywhere else.
      Re: Guide Hoses
      Guys,
      Do you use one?
      Thanks Again
      Renee
      I have the k1500 and the k60 niether have front guide hoses . I dont know how easy it would be with a sectional to feed the cables through a rear and front guide hose maybe you are talking about a self feeding machine
        Re: Guide Hoses
        the guide hose that comes with the K-50 is at best a joke. Rick had posted a solution but i never followed up on it and can't remember what it was.
        other than not being able to get close to the point of entry why would you need a front guide hose"? i'd probably make a snoot from PVC, but i don't know your situation
        steve
          Re: Guide Hoses
          Guys,
          Do you use one? sometimes, I had one for my 3800 and using a 2" pvc pipe is just as effective and easier to use. sometimes the co is 4' from the ground and it was useful for for this.
          If your machine came with a front guide hose, would you use it? no
          A front guide hose that is designed to be attached to roof vents(like all clear's idea)might be worth looking into.
          BTW; bring back the metal lined rear guide for the k50-works much better than the current model.
            Re: Guide Hoses
            I like to use the guide hose for the 40 under hard to reach kitchen sink drains, and hard to reach floor drains.
              Re: Guide Hoses
              Guys,
              Do you use one?
              Thanks Again
              Renee
              Hi Renee, what i would like is a platform the k-60 would sit on that is about 30" long (possibly hinged to take up less space) with rubber feet that has a 45 degree angle pointing out about 8" that has a detachable quick connect end placed in the upper portion of said 45 for use with a 1 1/4" steel reinforced guide hose about 30" long with a male adapter to fasten to the trap adapter coming from the wall and you would have to make it universal to adapt to both 1 1/2" and 1 1/4" drain lines and flexible enough to hook it up in any position. This would keep the plumber from having 2' + of cable exposed when he is reaching in the cabinet to feed the cable and make it more like going into a floor clean out and lessen the chance of getting tied up in the cable. Just a thought!!
              ________
              SUZUKI X-90 SPECIFICATIONS
              Mike
                Re: Guide Hoses
                mike, i think you lost me after the first set of numbers
                remember that a sectional is not typically a self feeding unit. it will wind into a drain and thread back out, but you need to give it some cable to do it.
                the front guide hose would have to be spaced away from the machine to allow for handling the cable and allow you to feed it.
                think along the lines of the k-1500 board buster set up. you need to have a foot or so of space to work the cable.
                i rarely use the rear cable guide.
                i doubt i will use the front guide.
                if i do, i just reverse the machine and run the motor in reverse, which is actually forward now. and attach the rear guide hose, which is the front now then you can feed from the other side and let it wind in.
                when i had my 7500 in the truck, i would use a modified guide hose since the machine was harder to get close to the opening.
                thanks renee for thinking of us sectional guys
                remember we're getting older
                but not any slower.
                go team geritol, mike, bill, rick
                  Re: Guide Hoses
                  LOL Rick,
                  Renee didn't say anything about sectionals. She must have meant for drum machines
                  Obviously I don't need a front guide hose on the K1500 with my speed and agility
                  Have you seen my video yet Renee? There arn't many women that can appreciate my first place trophy Just so everyone knows...I'm going to milk my moment of triumph for a full yearhttp://www.youtube.com/watch?v=bViCcRmSUeE
                    Re: Guide Hoses
                    Why is there 2 videos posted? I only posted one link?
                      Re: Guide Hoses
                      You wanted to make sure we know who the winner was?
                      I love my plumber
                      "My Hero"
                      Welcome, Phoebe Jacqueline!
                        Re: Guide Hoses
                        thanks bill for posting the photo. it's actually pretty close to the design of the sectional front guide hose.
                        you did as the contest stated. you busted the board
                        the rest of us actually drilled the board
                          Re: Guide Hoses
                          Because you're damn good!
                          "raises beer"
                          Sorry Renee for not making it to the roundup. Crashing my truck kept me from being there.
                            Re: Guide Hoses
                            PlumbersCrack,
                            I never got a change to say Congrats! You made me proud !!!
                            Renee
                            Product Manager
                              Re: Guide Hoses
                              Guys,
                              What do you think about Front Guide Hoses on Auto Feed Drum Machines?
                              Renee
                              Product Manager
