Clean my sink drain will ya?
    Re: Clean my sink drain will ya?
    I really dont know ???? you must see something I dont see?????
    Hell, even the height was set to code.
    Maybe your talking about the supply line that`s not hooked up????
    Maybe your thinking the No-Hub band is a fernco as it does look kinda dark in that picture???? (picture taken with my phone so it`s not near a clear as my good camera.)
    Hell I dont have a clue what you see with out you telling me
      you forgot to caulk the wall where the sink contacts it.
      how about the descanso fitting on your tube trap?
      here's a big hint
        Rick
        WTF are you calling a descanso fitting
        I tried to figure that out last night????
        Must be something that has a different name here????
          Ok here`s a trap just like the one I used SO what is a descanso fitting ?
          The only other thing hooked up to the trap is the drain extension peace off the drain and the trap arm. Other then that there`s a No-Hub to connect to the old lead in the wall
            You need me Rick I do things the easy way
            All Clear, it is an 1 1/2 OD Compression adapter. Designed to have a built-in stop so the tail piece can't push into the santee. It comes in MIP, FIP, and sweat.
            I love my plumber
            "My Hero"
            Welcome, Phoebe Jacqueline!
              All Clear whats up has the good weather been good to you and the boats or have you been working with no play time?
              Seattle Drain Service
                [QUOTE=All Clear Sewer;152156]Ok here`s a trap just like the one I used SO what is a descanso fitting ?/QUOTE]
                It is actually a desanco fitting
                I love my plumber
                "My Hero"
                • #23
                  Been working like a cat in a litterbox
                  • #24
                    We don`t use em here Just the trap I posted
                    • #25
                      We don't use them here either. We did in New York quite a bit, but I haven't seen any since I moved to NC.
                      • #26
                        I dont know why anyone would use one as the trap has a stop built in to it
                        • #27
                          I may have to rethink.... I get p.o.s.'s like this often and I just open them up again... I figure if they want a new sink that's what they'd ask for... this looks so much nicer though.
                          • #28
                            i guess i've never seen a tube trap with a built in stop on the tail piece
                            must be a non california thing
                            not talking about the slip joint connection to the pop up tail piece.
                            the tail piece to the san tee in the wall is the application
                            • #29
                              That confused me as well, Rick. Built in stop? whatcho talkingbout?
                              • #30
                                Are you calling the "Trap Arm" a "Tail Piece"????
                                must me a california thing
