Can I Hurt My Jetter/pump??
  • Can I Hurt My Jetter/pump??
    Hello buddies??...i recently bought a 75' 1/8" hose to add on to my 1/2" hose to clean kitchen sinks with my Trailor Jetter..i have a mini- jetter but sometimes it trips the breaker WHICH I HATE!!....i used the 1/8" hose with the Trailor Jetter the other day and it 'CLEANED THE HELL" outta the 2" k/sink drain!!..all kinda black gook came out. I actually got the pressure up to 2000 p.s.i.....i dont think it was putting out 12 gallons a min(maybe 10 gallons) but it did a surpurb job. My question is that will running the Trailor Jetter at 2000 p.s.i. with the 1/8" hose attached to my 1/2" hose..will that damage my motor or pump in anyway??.i dont think it will but i just thought I would ask the experts on here!!!.....Thanks in Advance!!
    Re: Can I Hurt My Jetter/pump??
    Make sure your not over heating the pump returning water to the tank. Other then that you should be able to turn down the RPM`S to get what PSI and GPM you want or need
      what do you recommend that i run the Jetter on....1500p.s.i.??.......at 2000 p.s.i. it cleaned the hell outta the line though.....but at 1500 i should be o.k. One guy i know here in Dallas rums his mini hose at 3000 p.s.i. with the 1/8 inch hose, so i guess he is over-heating the hell outta his pump huh??
        You can have 2000psi but you need to have bought the correct jet that ='s your jetters GPM. If you bought and are using the right tip you are fine.
        Seattle Drain Service
