Lubrication for my tube?
  • Lubrication for my tube?
    Now that I have your attention .....
    I finally recieved my new guide tube for the K-60 today. (A-60-12) Back ordered through Ridgid til the 30th but I found one in Iowa
    The tag on it said 'lubricate periodically'
    I've never lubricated my k-50 or k-1500 guide hose... ever
    How, what and why do I need to lubricate? It's just a tube!
    I have some Snake Oil will that work?
    Re: Lubrication for my tube?
    The residual wd-40 that is on the cables seems to be enough for the guide hose.
      I use vegetable oil on my k-50 hose.
        Veggie oil will become rancid after a while
        Crack, the guide hose is electrical metallic flex. You can use your extra KY. . .oh I mean snake oil. It will become stiff and rusty if not oiled up. It can snap
        The k-50 hose is now rubber.
        I love my plumber
        "My Hero"
        Welcome, Phoebe Jacqueline!
          peanut oil will be better than veggie oil.
          the rubber 50 guie hose (unless it's changed in the last 2 years) blows big chunks. it's too small and overly stiff.
          steve
            steve
            How......how in......how in the **** what..? how did my words get copied from my personals ad......?!!!!!
            Thanks PC, I thought I'd keep it on track to your thread title. I'm going to have a peanut oil bath to cleanse me of this dirty thread.
              Where do these kinky freaks come from???
              If he offers you french fries done in peanut oil, you should refuse.........
              I'm on "The List" and I love it!!
                If you're really worried about it, try using an air hose with a in line oiler. That should blow some lubrication down your hose.
                Get your mind out the gutter.
                  go snake a line at a restaraunt once in a while?
                    the only thing that will happen if the hose gets rusty is it will get stiff
                    sure it will be hard to roll it back into the cage. but it also will lay flat and straight. making it easier to get your snake out
                    you can snap the internal wound metal hose if you try to flex it once rusty.
                    it's basically the same as the grey electrical outdoor water proof flex they use for hooking up a/c units outdoor. ask sparky for some new 1.5'' flex next time.
                    now if you want a lifetime self lubricating hose. grab a piece of yellow hdpe gas pipe and you're set for life
                    it's fairly straight and stiff
