Easy Snake Job.....Yeah Right.
    Re: Easy Snake Job.....Yeah Right.
    Originally posted by DuckButter View Post
    Silicone caulking around the pipe while the rubber is peeled away, then roll it over the pipe like you do when you cut a fitting into a stack.
    Originally posted by All Clear Sewer View Post
    Silicone doesn't have a very long life span as we see it fail on motors all the time. I have never seen Teflon Tape fail so that's why I use it. I just roll the rubber back and rap the pipe then roll the rubber back forward and slide the band around it. Seem`s to work pretty good.
    Why not just use a shielded all rubber? wouldn't everyone sleep better at night?? rather then altering a fitting or application?
    Next time I will be using shielded couplings. Thanks again Aaron for introducing those to me on the Ohio Trip, still waiting for Fergusons to carry them I need a part # !!
    Robert
      what is this shielded all rubber thing???
        I think what you mean is a "fernco" style rubber with a SS sleeve, same as a shielded coupling with a thicker rubber, I've asked in the past and got a few dumb looks.
        It was for a very similar situation to yours, horrbly corroded CI underground with completely uneven surfaces.
        Let me know if you find anything...whoever coughs them up will make a fortune.
        As for the reliability of silicone, maybe a hot motor thats in constant motion might hurt the stuff, but my guess is it'll outlast the CI pipe it's applied to...just my guess.
          It is called a PROFLEX Coupling same as you would use if going from copper to PVC or C.I.
          They are also made by fernco a link to there spec is here
          http://www.fernco.com/proflex.asp
            Not as soft as the all rubber. These are just like no hubs, except one side takes up the extra space for cast iron to plastic etc.
            Robert
              Those work fine except when your working with close connections.
              They don`t roll back like No-Hubs.
              I get those at Lowes
              I think they look nicer the No-Hubs too!
