3/8 warthog
  • 3/8 warthog
    I have a 4000psi 16 gallons per minute pump can anybody tell me what size the jets should be on the 3/8 warthog
    Re: 3/8 warthog
    Give stoneage a call and they'll tell you exactly.
      Re: 3/8 warthog
      You`d be dumping alot of water back in the tank if you are to use a 3/8" Hog with that setup, you really need the bigger 1/2" or 1" models for that sort of flow. I hope thats not for 4" sewer.
        Re: 3/8 warthog
        Your right about the flow my figures where wrong its flow is 26lpm
          Re: 3/8 warthog
          Welcome to the site.
            Re: 3/8 warthog
            we need more info/ is it liters per minute? horsepower of motor and intended use.
            Seattle Drain Service
              Re: 3/8 warthog
              Hi Cuda I have a 24 hp honda with a 4000psi 26 litre a minute Annovi Reverberi pump with 120 meters of 3/8 hose for use on 4 and 6 inch drains
                Re: 3/8 warthog
                I can't remember the exact size for the 3/8 but it is their biggest I think. As for the 3/8 hose that is fine for 4" but you should really consider some 1/2 hose at some time it will give you a faster clean. 3/8 with lots of bends and 1/2 for cleanouts with straight shots to the street. And a 24hp honda will probably be around 2700 - 3200 psi with a jetter tip on at 12 gpm.
                  Re: 3/8 warthog
                  26 liter = 6.87 gallon
                  for that I'd guess 038's in the sides, possibly a little larger, something smaller, maybe 015, in front.
                  agree with previous reply call/email stone age.... they will need to know flow in gpm, pressure in psi, length (feet) and internal diameter (inches) of typical hose you use.
                    Re: 3/8 warthog
                    hi cave man
                    you should have a look on the stone age web page they have a list of jets for different set ups.
                    cheers WMD
