Overhead drain contraption
  • Overhead drain contraption
    To be able to run water and cable at the same through overheads. The down pipe directs the water into a trash bin, rather than on the operator and the floor. Especially handy for sub level areas of apt. bldgs. and parking structures where the drains are accessible. Note the no hubs for adjustment. Would also work to contain water while using a jetter. I like to cable the lines before jetting though.
    Would work on 3 and 4" too, just need a reducer.
    Wacha think?
    Re: Overhead drain contraption
    Nice idea. I may make one of those.
      Looks good.How long have you been using this setup.
      Kenneth Collier
      Maintenance and Sewer
      P.O. Box 9441
      Jackson, MS 39206
      (601) 613-2678 (Cell)
      drainman881999@yahoo.com
        The only thing I would change is to put a 16th bend on the end where the cable goes or water can comeout there. The little lip will keep water draining where it needs to go.
          Since it looks like you are creating a cross-connection what are you using to protect from cross-contamination?
            Good point
              I just cant figure out where this would be needed as most C/O on an over head drain are at a combo. The end of the combo should be a C/O with a fixture draining down the combo. If your worried about run-off out the C/O you can always install a bell-reducer with a fernco at the C/O
              Either way you shouldn't run water till you think it`s cleared
              That a big ugly cross-contamination and a big "NO"NO"
                TECHNICALLY you are hooking up domestic water directly to a waste like and that is illegal as well as possibly unsanitary.... what is the difference between this and shoving a hose down a cleanout? there is no solid connection from the drain to the domestic. You can alleviate this problem by installing a vacuum breaker on the sillcock before the hose or you really should hook up a portable RPZ. These are all technicallities though.
                  None of the lines we were cleaning ever backed up. It was preventive maintenance. And yes water was only after cabling each line.
                    Yeah I know, it's "not to code". But there was a vacuum breaker already in place and the hose was brand new so it hadn't seen any action either.
                      Well what the hell are you going to do set up an RPZ just for snaking the line? You can probably hook up a check valve on the end of the hose that you connect and that will help too!
                        My water tastes funny today
                          That's the very first thing I see, being a licensed backflow tester.
                            As an Engineer are you allowed to make suggestions like this? I checked my USC list and could not find an approved RP which you could move from one property to the other.
                            I'm just pulling your chain.
                              It's a curse we testers all share.
