Drainsters a couple of questions
  • Drainsters a couple of questions
    It's 2008,are there still people pouring grease down drains! Is most grease found in the
    kitchen sink branch? Any on the bath lines? Main lines? Who has the best 4 bladed cutters? Just trying to learn. Thanks' Tool
    Re: Drainsters a couple of questions
    I see a fair amount at about 50ish feet out in the main line.
    I have NEVER had a customer admit to dumping grease, just like no women flush mice
      Thanks Gene. So the accumulated grease tends to build up at around 50'from where
      the latera lor main begins?. Probably do so the lower velocity way out? Thanks
        Ridgid the 3/8" cable is C4 or C6 and the 4bladed cutters are T-213, 214,215.
        Most grease is found in 3 places;
        -in the pipe directly from the kitchen drain
        -where the kitchen line connects to the main line. The grease flows down then hits the cold water in the main and solidifies right in place
        -in the vent for the kitchen line. when you have a stoppage the grease floats to the highest point and thats's the vent. Grease clings to the sidewalls and you can have a stopped up vent before to long. Rare this happens but it is a possibility.
          thanks' Gear ,always amazes Me how much Knowledge a real Drainster has !
            Forgot the 4th place grease will be found; a belly or sag in the line. The dip causes water to slow and the grease just kinda floats around and ends up sticking to the sidewalls.
              All My bladed cutters are 2 blades , smooth and serrated. Use smooth for Kitchen lines? and serrated for roots ? Should I find 4 bladed cutters for My 3 different machines? Who sells them for General and Ridgid? Thanks'
                We use cold water under high pressure to clean the grease from the mains (1000psi). Bear in mind, all of our mains, both water and sewer are heavy wall plastic pipe by the name of sclair. I can't remember the chem. name off hand.
                I've also used hot water under high pressure for cleaning drains with a machine that could handle the heat of the water. I don't know if tephlon pistons could handle it.
                  I usually find grease a bit closer than 50'. More like 20'. But that's after dropping down from the main floor and going under the basement slab.
                  The two-blade cutter will have a problem with hard grease but the four will cut more smoothly. I'm assuming that the grease builds in a not-always-round form and any oblong hole will stop a two-blade head.
                  Most of my jobs since I got the K-60 involved cleaning the kitchen drain through the floor drain in the basement.
                    anyway--grease cutter ridgid makes works well on grease---obviously
                    i like 2, 3 , 4 blade cutters---i have a 6" 3 blade---sweet cutting tool
                    the 2 blade works real good too
                    also love spiral saw--strong cutter
                    and h cutter--extra tough
