Preferred cables and cutter attachment for drum
  • Preferred cables and cutter attachment for drum
    We've been down this road before, but I'd like to revisit it as I need to buy some new cables. Will be getting 1/2" in about 100' lengths. For use in 3" and 4" lines, typically paper clogs, occaisional object, occaisional minor roots. Typical access via toilet flange or cleanout. Have used duracable in the past, content with it as cable.
    Would like comments on cable from others who have used duracable and prefer other brands.
    Cutter attachment: Currently use the threaded stud on my 1/2 and 3/8 machines. Would like to get away from this as I do not have the option of reversing out when I get caught as the cutter tends to unspin itself from the stud.
    Have the sliding ends with allen screw locks on my 3/4. Have been happy with this. Considering it for the 1/2 and 3/8 but have some reservations; makes the non-flexible section at the end of the cable longer and is therefore tougher to get thru bends.
    Will have to redo all my existing cutters for new attachment and want to do it only once.
    I make custom cutters and need to be able to buy just the attacher for whatever system I end up with.
    Who likes what? And why?
    Thanks
    Re: Preferred cables and cutter attachment for drum
    DO NOT BUY DURA CABLE!!!!!!!!!!!!!!!!!!!!!
    if you want Dura cable I have one of the wire core 3/4 cables in one of my k-7500`s right now that I will sale you. It`s only done about 6 sewers and I`m taking it out before I use it again.
    I will only use Ridgid I/C Cables from now on.
    Enough said
      Thanks
      I use the slip joint ends also but I like general ends better thats what I would go with if I was doing it again.
