general speedrooter 90
  • general speedrooter 90
    anybody have one of these animals? was wondering if anyone could tell me the physical demensions of the drum that will hold 100 ft of 3/4 cable. Just aquired one and trying to figure out the cable lenth without physically removing it to measure it. Was guessing that the drum holds 50 or 75 ft but hoping someone familiar with this model could help me. thanks in advance.
    Re: general speedrooter 90
    not sure of the 90, but here are the specs for the 91.
    http://www.generalpipecleaners.com/p.../p11spd91.html
      I rock the 91...it kicks as$...ahem for a drum machine that is...has good power, the wire core cables (I have the 1/2" and 7/8") are strong yet flexible. Price is right
      West Trail Mechanical Ltd
      www.westtrailmechanical.ca
        If it was used you should pull the cable out anyway to check for kinks and oil it up.
        Seattle Drain Service
          Sounds like a common sense solution. What type/brand of oil should I use?
            General snake oil, at plumbing supply houses. Love My General Maxi Rooter
              All good oils but I can't stock them I use WD40 and lots of it.!
