foot switch general maxi rooter
  • foot switch general maxi rooter
    Need a new one I guess. have to re press often. Mail order or supply house please.
    Re: foot switch general maxi rooter
    tool. this is a basic air bulb. i do have them.
    check for generic bulbs on grainger, mcmaster carr or even the ridgid ones will fit. nothing special. chances are it's split at the nipple of the bulb.
    http://www.ridgidparts.com/rtctable.phtml?id=718
    look for part #10 but don't look at the price also the k-7500 part # is 60462
      try www.mcmaster.com
      this is a part # that should work 7467K53
        Thanks' Rick, Great catalog! Would #8152k11 for $27.96 work! Thanks Tool
          tool that will work, but you'll need to wire the machine permanently on and then plug it into the piggy back cord,
          if your machine is still working when you blow into the tubing, i would just change the bulb with the ones 1 posted.
          if the entire switch assembly is bad, then it would be a cheap fix for $27.96.
          try blowing into the air tube and see if it works good.
          remember if you've been drinking
          the machine won't start
          nothing like a drunk drain cleaner
            tool, good news
            i was at the supply house today and bought you a brand new general air bulb
            the part #gwmr-308-d, foot pedal only.
            better part is it was only $10.77 plus tax
            p.m. me your # and i'll ship it to you
            i think we're up to a side of beef now
