A Tale of Two Drains and Two Snakes
  • A Tale of Two Drains and Two Snakes
    Today I did 2 drain jobs with 2 different snakes because of the jobs.
    1st job 4 unit apartment building clean outs located in crawler that was 3' tall at the opening and 8" less going under the beams. A real crawl space lol.
    The first clean out was located about 20' in perfect job for the k-60 because of the low height. Drug it all in there took about 1 hour to clear the line (roots and white mice) Yes I could have removed a toilet and used the drum but in this run down place it would of just opened up a bunch for problems.
    K60 was perfect to use due to it's size.
    2nd job
    100 year old house in city 75 ft to the sewer clean out inside garage level entry to get in. Rolled up with the Maxi rooter sat down on my bucket and put in forward grind grind grind whoosh, hit reverse on the feed pulled it in cut off the roots, ran it back out then back in a few more roots, got off my bucket, wheeled it back to the trailer, wrote the bill got paid and left.
    Easy as it should be, damm I like sitting on that bucket making money!
    2 different jobs 2 different snakes.
    Seattle Drain Service
    Re: A Tale of Two Drains and Two Snakes
    nice photo cuda.
    careful how you post, you are sounding like dunbar and allclear
      I know the whole bucket thing lmao.
        Nice job Cuda. What did you use for a tip on the second job?
          Thanks Cuda , My son in law is in Duval Wash. Earth.heat.com . They got outa plumbing to do Geo. What You experience in the Wash winters, is tougher than most! WET CRAWLERS.
          I'm dryer here but use 2 plastic snow sleds with pull ropes in crawlers. One for tools
          one for My back,to keep dry! PS nice You still have a Salmon season, Calif. doesn't !
            I usually use the arrow bit first to get it draining and to prove it is possible to get thru, then I use the root saw most times, but I did this house 2 years ago and knew the line so I just went with the root saw.
              I don't mind the winters here just stops me from riding my motorcyle
              The crawler in the picture was a lake because all the low life tenants let there lower toilets over flow for a few days because they are scared to call the problem in , they where using the upstairs toilets and all the water was just flowing into the crawler yuck
                A few times over the years I had three or four machines set up at the same time at the same house the home owner would ask how meany workers are here. Just me but every drain took a deferent machine but after I clear out all the side drains I like to rerun the main line so it wont stop up again. I had a lot of customers who wanted every drain in the house cleaned when they found out it would cost extra to do more then one and more if I had to use a deferent machine. They usually said they thought I would charge for just the one. 5 hours the same as 1 hum I wish my mechanic would do that.
                  often overlooked problem with a main drain stoppage is the other branches getting clogged also needing to be snaked themselfs. Most people call right away but some don't and all the other drains can get reversed plugged also.
                    Cuda, we need to start a club of guys who use BOTH drums and sectionals. These guys who only use one or another are simply limiting themselves!
                      How'd the k60 do with no guide hose over the plastic? Did the cable wrap up in the plastic
                        Hummmmm..... I don't feel limited
                          I use a piece of 2" ABS with a weight on it like my ridgid radio or even the cable carrier. First time I used it though I remember getting all rolled up in bushes lol
