K 50 maximum length and cleaning size
  • K 50 maximum length and cleaning size
    I have come across a k 50 cheap what is the maximum size and lengths you can use these machines.
    Regards
    Greg
    Re: K 50 maximum length and cleaning size
    5/8'' cable 125'
      And while your on the K-50 subject Rick what all round 5/8" 16mm cable would you buy the 2.3mt tight-wind cable or 2.3mt the all-purpose wind cable or 3.1mt the heavy-duty wind cable.
      Tony
        Tony
        i use the all purpose wind with mine.
        if it requires anything more, i use the k-60 with 7/8'' cable.
        it's amazing that there are 3 - 5/8'' cable choices for the k-50 and only 2 choices for the 7/8''.
        the standard c-10 all purpose and the newer hard to find c-10 inner core.
        i have 2 sections of the c-10 inner core and run it in the first and last position. this gives it the stiffness to clean 6''/ 150mm pipe and not flip.
          Thanks for info Guys
          Keep up the good work on the discussions I enjoy reading them.
          Regards
          greg
