another "CANT FIX STUPID"
  • another "CANT FIX STUPID"
    We`ll see if anyone can figure out the job I did yesterday.
    I get a call to go 60 miles away from the shop in another town.
    All the plumbers that showed up to this site told the HO they needed a new sewer.
    Sewage was surfacing about 40` from the house out by the alley next to a shed.
    I first asked the HO if they paid a city sewer bill so I knew that there was not a septic tank as this house was on the edge of town.
    I told the HO we needed to move the shed first before I could tell what was going on. I had an Idea in my head
    The other plumbers told the HO he damaged his sewer when he placed the shed.
    I called Dig Safe for locates and told the HO I would see em in the morning and we would fix this problem.
    So take a guess what was wrong ?
    Re: another "CANT FIX STUPID"
    They used the septic tank as the foundation/footer for the shed?
      sump pump/ sewer ejector burned out/ un-plugged.
        Sent From The StoolBus
        www.appletondrainandsewer.com
        Appleton WI, 54915
        1-920-284-7471
          Was the shed there outhouse? And full ?
          Appleton WI, 54915
          1-920-284-7471
            WOW.... so colse, but so far away.....rotflmao
            Someone will guess it. It`s really easy. It`s one thing that you should always check when doing sewer work.
              the shed was built on top of the sewer service. this caused a backup to the house and/or broke the saddle?
              or
              check slope?
              or
              tree roots. looks like the HO cut a tree down?
              Vince
                I have seen them sitting on top of a manhole.
                Kenneth Collier
                Maintenance and Sewer
                P.O. Box 9441
                Jackson, MS 39206
                (601) 613-2678 (Cell)
                drainman881999@yahoo.com
                  Something you should always check when doing sewer work?
                  I always check if they are on city sewer or septic,
                  I also check if they are on a sewage pump or not,
                  then I check for the best cleanout access,
                  ...then I clean the drain.
                  So, if its not a septic tank and its not a sewage pump, then it must be a crushed pipe under the shed, or maybe even a manhole!
                    We posted 'manhole' at the same time! Great minds think alike. Hopefully we are right.
                      They cut down the tree but they didn't kill the roots.
                        Not his line, someone else's?
                          MISSING CLEAN OUT CAP OR PLUG SO SEWER BACKING OUT OF CLEAN OUT
                          JERRYMAC
                          E-MAILJERRYMAC777@GMAIL.COM
                          FIRE SPRINKLER CONTRACTOR,
                          SINCE JAN. 1989
                            i missed you.
                            where yu been.
                            busy i hope.
                            Vince
                              I agree with you service guy, its on top of a manhole.
