1" 1/2" trap
  • 1" 1/2" trap
    i tried to clear a tub drain today my k-380 was all i had on my truck i couldn't get any of my heads past the trap i ended up cutting out some of the galvanized pipe (its a good thing i went in the crawl the drain pipe was eaten through in 2 spots) my question though is there a head that will make it through a 1"1/2" trap?
    Mike
    www.plumbinginclarkcounty.com
    Re: 1" 1/2" trap
    If it's one of those old cast traps, they sure had a very tight bend. In a case like that, it might just be better to replace with the longer plastic trap or equivalent in C.I.
      Re: 1" 1/2" trap
      You think getting through a 1 1/2" trap is hard then you should try our drum traps. Here all shower/tubs are piped with them, so if you don't get the clog in the first foot or so you have to search for the access door that almost never exists. Then its time to crawl,bust open wall,or bust open ceiling.
        Re: 1" 1/2" trap
        Haycad , are You talking 3/8" or 1/2" cable ?? No top Gun??
          Re: 1" 1/2" trap
          I use a top snake for bathtub drains 1/4" or 5/16 hard enough on cast with these size cables.
          Seattle Drain Service
            Re: 1" 1/2" trap
            for most tub/shower drains i use the K-39. it'll make the bends, grab the crud (hair, sludge, etc) and retrieve pretty easy.
            sometimes the 5/8 will work but i start with the 39. usually in and out
            steve
              Re: 1" 1/2" trap
              3/8" on the k-380 i've used the auto spin before but the cable lasts about two cleanings and its shot
              Mike
                Re: 1" 1/2" trap
                Mytana makes a 1/4" cable with threads to put on the end of 3/8 cable male threads.I run with the K39.Works well on lav lines too.No pulling the trap.Just pull out the pop up and go!Of course even then there are lines with toothpaste caps and weird stuff and you have to chase down with 3/8 cable and a good cutter.
                  Re: 1" 1/2" trap
                  I used the Super Vee on a tub last week - before starting I pulled out the 3/8" cable and put in the 1/4". Quick and easy. Dayum, but those General cables are nice.
