Roots in closet bend
  • Roots in closet bend
    HEY RICK;
    THIS IS ONE I DIAGNOSED AND TOLD
    HOME OWNER HOW TO CORRECT DOWN IN AUSTIN, TEXAS BY PHONE
    THIS WAS GROWING AROUND THE PVC CLOSET BEND AND THEN DOWN INSIDE,
    WITHOUT SHOWING OUTSIDE BASE OF TOILET
    JERRYMAC
    JERRYMAC
    E-MAILJERRYMAC777@GMAIL.COM
    FIRE SPRINKLER CONTRACTOR,
    SINCE JAN. 1989
    Re: Roots in closet bend
    jerry, i've had the same thing on both slab homes and raised foundation
    slab i can understand, raised foundation threw me
    apparently the toilet was dripping just enough past the wax that it allowed a vine to grow and follow the drip 2' up through the sub-floor and under the wax and into the bend. creating a stoppage.
    when i attempted to plunge the toilet and failed. i tried my auger. pulled back roots couldn't believe it. so i pulled the toilet and saw the problem.
    crawled under the house and cut the large bright red vine. no it was not licorice
    first time i've ever seen this happen on a raised foundation.
      not uncommon around here.
      i even had one in a bath sink drain. my K-39 (and their checkbook) got a workout that day.
      steve
        You guys must have some smart roots. Mine are too dumb and do things the old fashioned way, grow through 5+ feet of ground to get to the pipe.
        I wonder if it has anything to do with the cold we get here???
        Anyone in cold climates see this happen?
