Sectional Drum
  • Sectional Drum
    I would like a drum machine that runs sectional cable. Possible to achieve the dream? Ideas?
    Re: Sectional Drum
    probably not too easy. problem is the open wind cable will stick and grab to each other. hard to push and pull back into the drum.
      Re: Sectional Drum
      That's what I though too Rick.
      Then I thought about a coiled tube throughout the drum to hold the cable links & coils away from each other.
      There would be issues with that of course. Additional weight etc.
      But I'd like to think nothings impossible when forced to think differently.
      Thanks.
        Re: Sectional Drum
        Cement mixer type Drum that has a corkscrew interior to keep the cable manageable?
          Re: Sectional Drum
          I see Hacktown forces you to think outside of the box too.
          Something to think about. Okiebill. Thanks.
            Re: Sectional Drum
            Try Electric Eel model N. Uses 5/8 sectional in a drum. Mine holds 75'. Each section is 5' long.
              Re: Sectional Drum
              Thanks smitty. I'll give it a look.
                Re: Sectional Drum
                Looked at the website and they give some conflicting information. On the brochure page they say it can hold 75' of the sectional cable and in the instruction page they recommend only 25-30 of cable. Not enough cable imo. I'll stick with the k50 in this case.
                If I had access to an open drum cable machine such as a gorlitz, I would try with the sectional. I load/unload my cage with all the cable loaded up and I can pull the cable out rather easily. What's the difference between the cage laying down or in the vertical position?
                  Re: Sectional Drum
                  I know what you saw and it is old info.
                  Drum now holds 75' dualmatic cable. I have this machine and can assure you it holds that much sectional cable. This drum was re-designed several years ago to hold more cable. Call the company if you don't believe me.
                    Re: Sectional Drum
                    I use to use the eel my dad invented it but he switched to a single cable when the dual wouldn't go through. That was before auto feed so pleas don't blame him for the way it was set up ( hard to put a auto feed on it ) I submitted a design to them for one to use a bigger cable with the cable that feed its self in and out the auto feed was not needed that much. But they said they could not make it and went with the 5 so I went with Ridgid. Marco will also use the 5/8" eel cable but you would rely need a 7/8 dull cable to be much good.
                      Re: Sectional Drum
                      I must ask WHY??????
                        Re: Sectional Drum
                        I felt the same way when it was posted.
                        I guess rational thinking is, "How can I make my sectional operate like a drum?"
                        The mess, the extra work, the down time hosing off cables is a frustration I ended in 1989, and vow never to go back. Lots of open drains to prove my switch made life easier, a lot easier and customers happy.
                        But, everyone needs to get injured and find out how to work smarter, not harder to understand why.
                          Re: Sectional Drum
                          Oh, Ok now I understand
                            Re: Sectional Drum
                            I've got limited experience but like the flexibility of sectional cable even in larger sizes. But drum operation seems to have some advantages in speed & being cleaner.
                              Re: Sectional Drum
                              the exact reason i use sectionals. i don't need to get hurt to learn anything. smarter not harder
                              steve
