Brown friday, sewer hydrant
    Re: Brown friday, sewer hydrant
    Around here the City will call the EPA on you and they will make the rest of your life HELL!!!!!!
      Originally posted by drainman881999 View Post
      How would you have went about doing that job?The clean water act is something to think about.
      Not to fault Rick as I would have done it the same way.
      But you can also drill the cap a use a shop vac to catch it as it comes out. Once the vac fills I plug the hole with a pencil and dump the vac in a trash can. Once the clog is clear I pump the cans back into the main (makes a good test).
      I once hired a septic truck to vac when I pulled the cap as I knew it was going to be a big one in a basement.
        Around here the city says If you didn't see what I did last week then I didn't see what you just did.
