Area drain dirt packed , big time
  • Area drain dirt packed , big time
    1927 circa S.F. home. Alley way drive,drain in front of garage door apron. Second home Ive cleared in alley way. Vacuumed about 1 1/2 gts. dirt. Use super vee 3/8s" cable with flexible arrow,with water. Took 1 hr. same as 1st one. Hard to tell ,think trap is only 2". Owner Guessed it was blocked 40 Yrs. I'm a cub scout in this. Any suggestions,appreciated. Used k- 375 with 1/2" cable first. couldn't flex the trap, I think. No, don't have a jetter
    Re: Area drain dirt packed , big time
    How far can you get into the pipe? Is there a trap or is it just packed with dirt. Could the pipe be collapsed. Can you camera the line?
      Think a blow bag would work?
      Could dig the trap up but I'm guessing the HO doesn't what to invest any real expense if they have lived with it for 40yrs.
        Thanks' I did clear both drains . Yes traps in both C.I. 1927 circa. Surprised It took an hour each. Is this My inexperience ? Should I done something more efficient? Thanks Tool
          tool, this being an area drain, does it drain to the street?
          can you snake from the curb back?
          out here we run into lots of area drains that are done in cheap styrene pipe and fittings snake has a hard time making turns in the tight turn 90's and joints are not glued. root city
          adam knows first hand what i'm talking about
            You got the job done which is all that matters in the end. I don't think an hour is an unreasonable amount on time each. A small jet would have saved you some time.
              The area drain runs under garage slab to house lateral.
