Drain Cutters
  • Drain Cutters
    Just getting some ideas. For the drain guys. Could you list your cutters or heads, what you use them for, & why you prefer them. I have a set and would like to think I have some common sense but honestly don't know if I know the best ends for the jobs.
    Thanks.
    Re: Drain Cutters
    I am going to assume that you are referring to cutters for a cable machine versus a jetter. I have a full set of cutters that came with my machine (Drum). The only ones that i use is the 3" Cutters which i use together as a double blade. Sometimes if i cant get the double through clog i will go down to one blade and then back to the double once some of roots are cleared. If i suspect that pipe is broken and/or seperated then i will use the head that looks like a spear to attempt to unstop the line at which point i would sell camera job.
    As for my sink machine and pistol drill the only head that i have ever used is a "drop-bulb auger"? Looks basically like the end of your closet auger!!
    That what you were looking for?
    I don't have a jetter so i am no help there, but i understand "warthog, warthog, or a warthog"" will work well in your application.
      Re: Drain Cutters
      what machine, cable and size pipe?
        Re: Drain Cutters
        I carry 3 of every type they make from ridgid, eel, and general but I use a lot that I invented my self, along with some home made and factory adaptors
          Re: Drain Cutters
          out of respect for Ridgid (love the seesnake, wrenches, wet/vacs, pipe threaders) I prefer another brand of sewer and drain machines so I wont say the name. Don't know if ridgid uses different terms for their blades - but here i go.
          I use 2 1/2 inch pear shaped blades for 3inch roof vents, and closet bends. 3 inch pear shaped blades for 3 to 4 inch clean outs. 5 inch "big chuck" blades for 6 inch. a whip for 2 inch drains (no blades in 2 inch). a combination whip cutter for stubborn sewers, followed by a mini jetter (3000psi 5gpm) if blades or whip doesn't work. mini jetter nozzles - if working from upstream to downstream I use a nozzle that has 3 jets shooting forward 4 shooting back to push "muck" downstream. from downstream to up stream I use a nozzle that has 1 jet shooting forward and 4 shooting back to pull the muck downstream. Don't know the names for these nozzles. Don't have a "big" jet yet, priced one at $32,000 I'm just not getting enough demand for it to warrant the purchase, yet.
            Re: Drain Cutters
            I don't have many machines yet. I use an I95 sectional. Link pictures would be great if anyone can post those. The names & descriptions sometimes get me lost.
            Thanks.
              Re: Drain Cutters
              Thanks.
              the i95 is very similar to the k-60 it uses the same cables and has the same ridgid ends so they will interchange
              for 5/8'' i like the bulb auger t202, straight auger t201, 4 blade cutter t213 and the drop head t217 with caution.
              for 7/8'' i like the straight auger t101, funnel auger t102, 4 blade 3'' t113, sharktooth t-150-1 3'', 150-2 4'', and of course my favorite root cutter t111 3'' spiral root saw.
              then there are the customs like my g17 4''x 3'' double pear offset cutter and my reverse wound continuous corkscrew auger.
              you can be creative and adapt almost any cutter to fit the blade holders. buying generic blades are much less than factory blades
                Re: Drain Cutters
                For 4" main
                My most commonly used head is a 3" spiral root saw.
                If I have camered the main I will use a 4" spiral root saw or a 3-6" expanding cutter, depending on the condition of the pipe.
                Spiral root saw does a good job on roots but not when the pipe is packed right full. Like the kind you get at the home of a little old lady that has lived alone for ages. I found that a 3" heavy duty C cutter works pretty good in this situation to get it open then finish off with 3" then 4".
                  Re: Drain Cutters
                  I use the k-60 with 7/8 cable most times, a super-v and a small auger bulb. on the 7/8 cable, I go with a retreiver head of 1 inch and 2 inch. also a C-cutter of 3 inches in size.....there's many others that are around though. good luck.
                    Re: Drain Cutters
                    Thanks.
                    this is the only pic i could lift from their website, this is the 3 inch pear shaped blades, works for most applications.
                      Re: Drain Cutters
                      Most helpful. Thanks. Is that pronounced A-Bear like the pro quarterback?
                        Re: Drain Cutters
                        yes - like Bobby Hebert
                        it's a cajun (french) name as common in south louisiana as smith
                        I'm HER-BERT when I leave louisiana, lol
                        the name of my company makes more sense when the name is pronounced right - it rhymes
                        there is a local company called A BEAR refrigeration, but I suspect they're Hebert's that gave up explaining the name.
                          Re: Drain Cutters
                          Good name for your business. I thought it probably rhymed.
                            Re: Drain Cutters
                            Here is my usual set for mains,double 6" but I like a 6x4 blade set up.
