Hand built redwood septic tanks in Ca.
  • Hand built redwood septic tanks in Ca.
    Met an old carpenter that told Me this years ago. He use to hand dig septic pits and build
    the tanks from redwood! Any one have any knowledge of this? What size timbers ect.?
    Re: Hand built redwood septic tanks in Ca.
    I've found a couple old farm houses that used the old family car for a septic tank.
    Sewer main snaking (roto rooting). Sink clogs. Sewer backup. Pipe inspection/locating. No Dig trenchless repair. Root clog removal.We are NOT to replace your local Plumber, as we do not do plumbing. WE ARE YOUR DRAIN CLEANING EXPERTS!!! waterville winslow bangor augusta skowhegan fairfield pittsfield oakland
      Oh yea. Before sears and Montgomery ward started selling round metal septic tanks they would build wood ones just like wood water towers. They would use 4 X 4, 3 on each side then use 2 X 6' S, on the inside for the walls and top. They were a son of a gun to clean the wood would fall off and it would suck on your hose. The board was too big to get out as they were too solid yet. The top was made with 1" wood with concrete poured over it, sometimes the inside had tar on the inside depending on what type of wood was used. I have seen wooden barrels used, old boilers, heating oil tanks, rocks, blocks, brick, ruff box's, any thing that would hold water.
