Where is it??
  • Where is it??
    Somewhere on the Rigid site there is a chart with pictures of 16 different cutting heads. Does any one know the web address for it or can you post a link? I have looked all over but can not find it.
    Re: Where is it??
    you need the ridgid bible
    get the ridgid catalog and you will be up to speed
      Re: Where is it??
      Look up the type of machine you have and scroll down the page. The different cables and tips that are available for your machine are towards the bottom.
        Re: Where is it??
        Thanks guys, but that is not what I am referring to.
        There is a page that is called"Drain Cleaning" that has pictures of 16 heads along with another picture of each head in action inside a pipe. At the bottom it says "tool tip". Printing it out produces a very poor reproduction.
        This may be a reproduction of a page in the catalog, but I can not find it. It would make a good sickey on the drain cleaning forum.
          Re: Where is it??
          thanks jim, that's the one in the ridgid bible i was referring to.
          i blew it up for others
            Re: Where is it??
            Yep that's it. Is it available in a PDF, or similar file that will print out clearly?
            I tried to open the online catalog but get a message that the link is broken. Do you know if it is temporary or is it always broken?
