Is there a difference between the k50 & k400?
  • Is there a difference between the k50 & k400?
    I have the K50. Very powerful, very expensive, and a pain to set up.
    The K400 has a 1/3 hp vs. 1/6 hp, self contained, heavy, on wheels, and cheaper...but limited in length of cable.
    Are the two comparable as far as drain cleaning power (with the 1/2 cable)?
    Re: Is there a difference between the k50 & k400?
    If you are looking for power the K50 is the machine. The 400 is a good machine for quick and easy light blockages. The K50 may take a little more setup but it is a superior machine.
      the gentleman from Greenwich speaks the truth.
      steve
        prime example yesterday.
        2'' laundry standpipe stoppage, continuing to kitchen. no c/o.
        ran 5/8'' sectional cable with bulb auger into 2'' laundry standpipe, through trap and 35' to clear stoppage and continue into 2'' common kitchen line.
        hit hard lint and grease.
        try getting a 1/2'' drum cable through a 2'' p-trap
        i set the k-50 on top of the laundry machine with a neoprene yoga mat
        try that with a 400
        the 50 has the power, and the adaptability to get it done.
        the instant clutch keeps it safe and the ability to run both 5/8'' sectional and small drum canisters. i personally don't use the drum, but others do.
        try lifting a 400 with 75' of cable onto a roof, compared to a 50
        need i say more
          Thanks. I was just curious. I have had nothing but good luck with the K50.
