gmp or psi? need advice
  • gmp or psi? need advice
    hi as I probably mentioned in my previous thread I want to buy a jetter to start a drain cleaning career.
    Now among the ones ive seen, there are two that I liked most and I need to make a choice soon. one is 4gpm 3000psi and the other 5.5gpm but with lower psi 2000 (they're from different manufacturers)
    I first thought i'd go for the 5.5gmp as I prefer something stronger, but now this pressure issue got me totally confused.. and i'm not quiete sure anymore which one is really stronger in performance.
    Any idea? thanks!
    Re: gmp or psi? need advice
    the 3000# at 4 gpm is a better unit.
    the 5.5 at 2000# is a little underpowered once you take away for friction/ pressure loss.
    both should be 13h.p
      I bet you they are the same machine as in change the tip orifice and now the 5.5 @2000 now is 4 gpm at 3000 psi so buying either machine the results are the same with the jetter tip and hode that you buy and put on.
      Seattle Drain Service
        ok thanks for the input!
          can't be. the pump is a positive displacement. it has a certain volume at a certain rpm. i rather doubt that the maker would vary the rpm that drastically to increase/ decrease the volume close to 50%.
          chances are the 5.5 @ 2000 is a more expensive pump.
          now a sump pump/ centrifugal pump will vary the gpm at different head pressures. but then again they are usually high volume low pressure pumps.
            Any idea? thanks!
            Listen,go with Rick's advice.
            Take a deep breath,jump right on in,and come back and give us your success stories.
            (P.S)The water's are not that deep,but start small.
            Kenneth Collier
            Maintenance and Sewer
            P.O. Box 9441
            Jackson, MS 39206
            (601) 613-2678 (Cell)
            drainman881999@yahoo.com
