Splatter gaurd
  • Splatter gaurd
    I have seen a splatter gaurd on the net before that stands over the machine as you are rodding to prevent splatter.
    Does anyone know where I can find these things?
    Do any of you use something like this. I am sick of my 300 machine splattering all over the place!
    Thanks!
    www.firstresponsedrain.com
    Re: Splatter guard
    Gorlitz drain cleaners out of Santa Fe Springs, California (LA area) sells them in thier catalogue. I use a folding splatter guard when retrieving wet cable back into my open reel machine. Its works great. Even some closed drum machines can still sling it some without the folding guard. Hope this helps
      Re: Splatter gaurd
      Towards the bottom of the page you will see a “Snake-Shield” Spatterguard.
      http://www.quadraplexinc.com/machine.html
        Re: Splatter gaurd
        GORLITZ!!!!!
        I knew I saw them somewhere!
          Re: Splatter gaurd
          i thought you use a closed drum on the 300?
          i have a 300 and the only splatter is from the exposed cable.
          gorlitz is close by and the 2 brothers that run it are nice guys
          they'll be at the pumper show.
            Re: Splatter gaurd
            It is a closed drum but it still comes out around the inner drum somehow.
            This never used to happen with the old 300's. When I was still working at Spartan, they had to redo hundreds of inner drums due to this problem. I had customers with this problem for a short time and we would end up giving them a new inner drum that had been tapered further.
            I think we are going to use some foam stripping to seal it somehow.
              Re: Splatter guard
              I agree, that's what I use. They have two different sizes.
              And I line the floor with newspaper.
                Re: Splatter gaurd
                I use autofeed enclosed drum machines and about 3' of 2" poly pipe, only about 1' of cable exposed, safe and clean!!
