Thawking a
  • Thawking a
    So this is the almost completed "THAWKING A" (say it fast).
    It has been tested on 2 real world frozen well lines and preformed just as well as the $2700 Magikist machine.
    Re: Thawking a
    I tried some more pics but having trouble with uploading pics lately???????
      Re: Thawking a
      Gene,
      did you make that yourself?
      Vince
        Re: Thawking a
        Very Cool Gene
        What is it?
        What does it do?
        Where can I buy one?
          Re: Thawking a
          i bet rick doesn't have one
            Re: Thawking a
            i sure do
            i have the same exact wire welder
            what do i need a thawer for
            i needed to run the a/c today in my truck
            please post some photos of this. is it some form of a hot box for your jetter?
              Re: Thawking a
              The "THAWKING A" is used to thaw water mains.
              As it is, it's best use is for well lines, but with very little work it will be ready for town/city service lines.
              That pic was a kind of before pic. For some reason I am not able to post the 'next to finished product'. I have painted the case black and have flames coming up from the bottom and looks friggin cool.
              I am quite proud of it as I have never worked with sheet metal and yesterday that case was a flat piece of 24" X 36" sheet metal.
              I just wish I could post some pics of what it's like now, but each time I try I just get 'UPLOAD FAILED'.
                Re: Thawking a
                Check file size (max size varies for each file type) and file format (JPG, GIF, PNG, etc) are correct.
                  Re: Thawking a
                  Thanks Bob, it was the file size. I've been having problems with my photo program so I over looked the obvious, some how my camera settings were changed.
                  here is the almost finished results. I'm going to have my graphics guy make a decal.
                    Re: Thawking a
                    very nice Gene.
                    it's amazing what one can do with a little imagination.
                    to get myself started, i'm going to get one of those cheap high pressure car washers and adapt it to jet frozen water and sewer lines.
                    i don't know how long it will work for, but i'm hoping long enough to buy/build a heavy duty one.
                    thanks for the pics.
                    Vince
                      Re: Thawking a
                      Thanks Vince,
                      A few days ago the case/hood was just a 24" X30" piece of sheet metal.
                      I think I did a pretty good job for never having worked with it before. It's amazing what some cutting, bending,welding, A LOT of grinding (I suck at welding), some bondo, a LOT of sanding (turns out I suck at bondo too), some paint/primer, and some old school flame decals can do.
                      I'm sure a Tin Man would have a field day with me, But I like how it came out.
                        Re: Thawking a
                        looks good let us know how it works!
                        Mike
                        www.plumbinginclarkcounty.com
                          Re: Thawking a
                          Got enough work thawing to pay for the insurance? I looked into that a while ago and it would send my ins through the roof to add thawing.
                            Re: Thawking a
                            Save your photos on your HD at whatever resolution you took them at, but when it comes time to post one just right click and resize it to 640x480, even 800x600 will work and still be big enough in most cases to view.
                            If you don't have the image resizer powertoy installed, go here and get it:
                            http://www.microsoft.com/windowsxp/d...powertoys.mspx
                            Scroll down and find Image Resizer, and while you are there grab all the other powertoys for Windows XP.
                            DO NOT, repeat, DO NOT try to use these on Vista, they will not work except for maybe one or two of them. You will do more harm than good, and you will be cursing the day you downloaded and installed them under Vista (or at least tried to install).
                            None of the XP powertoys were incorporated into Vista unfortunately, and Microsoft has yet to release any powertoys for Vista. Microsoft Powertoys got their start under Windows 95, and there have been Powertoys that worked on every version of Windows since up until Vista.
                            There is a powertoy like image resizer for Vista. I use it on my Vista computers. I will have to look and see if I can find the source for it. Took me a couple weeks to turn it up over a year ago, but it works fine and exactly like the XP Image Resizer powertoy.
                              Re: Thawking a
                              Thanks Bob, but guess what? I have POS Vista.
                              I can resize with what I have, but it's a process.
                              The problem I'm having with my photo program:
                              When loading pic's from card, program stops.
                              pop up says something to the effect of: Com Surrogate has closed this program to prevent data excursion.
