auger marks in WC
    Re: auger marks in WC
    I'm pretty sure EVERYTHING is crazy expensive in Rankin Inlet.
    Didn't you post pics of prices at the grocery store once? A liter of diet Coke was like 8 bucks?
      yeah, that was a while back.
      price has probably gone up some since then.
      last years fuel resupply happened when the price of fuel was through the roof so we'll have a fixed high price until next years resupply.
      all of the people that own large displacement engines are a little light footed these days.
      Vince
      this is why sometimes a guy have to figure out a differnt solution and go with it. thankfully, i got you guys.
        plungers don't mark and work 90% of the time
        don't you have the rubber boot on the end of the auger?
        the only time i see a scratch is when the auger has flipped over trying to get through the horn.
        But which plunger? I use those blue accordian style ones. It wqrks much better than the traditional style
        Wes
          Man you got it ruff. acid is $ 2.50 a gal. coke is $ 1.00 here.
            Magic eraser works for me.
              I didn't know anything got the marks out, learning something new here. I just learned a long time ago, to not scratch the porcelain.
              I like the 6 ft augers. Not for the extension, which is almost never needed, but because the bigger tube fits into the drain better, giving you better control. With the rubber boot, I haven't scratched a commode in many years.
              If you're flipping the auger in the commode, pull the commode to get the object out or replace the auger. It's probably too worn and/or kinked if it's flipping often.
              Like Rick said - plunger works 90% of the time. Of course, the customer will find the price harder to swallow if they see you use a plunger.
                That's why I don't do it, it's like being a hack. Of course, if you're working for peanuts to begin with, then doing it cheap matches the talent. The chances of blowing that wax ring out is significant and I won't take that chance just because I can.
                No matter what, I don't put marks in the toilet, ever. The closet auger has a rubber sleep on the bend that prevents that. Otherwise the customer has a legit complaint about the damage created.
