No good deed shall go
  • No good deed shall go
    Home next to the one I'm working on had a toilet blockage Yesterday. I brought My closet Auger and K375 today. Ran all 6 ft.on the auger, nade. Pulled john, ran garden hose in it paper ran out. Ran 50 ft. with 1/2 cutter no blockage. installed new wax ring ,pointing out the old horn one is a poor choice. After hook up ,No flush!!Still some thing in toilet trap!
    Augured more aggressive and it cleared. Cleaned up and left. Neither husband or Wife said thank You.I had no intention of charging them, but a thanks would be nice. After all these Years , that's it !I just don't understand some people. NO MORE FREEBEES!
    Re: No good deed shall go
    Why did you do it for free, and then expect something in return? Dumb.
      Is a thank you too much to ask Carl ???? that's all I wanted. I saw that they are burdened with a child [14 with problems] Just an act of Kindness.Ifound out later He uses REAMS OF TP!
        With more expierience Tool you'll know when there's a stoppage in the toilet or farther down the line. Just because the auger made it through the toilet once doesn't mean it's is clear of debris.
        In this situation I might have augered the toilet at no charge in hopes of getting future business from them. But pulling the toilet and running a snake, no way....you pay!
          Thanks Carl ,now I know to auger a few times.
            It always blows my mind when I auger past an object. I've snaked thru long paper clogs with massive cutters repeatedly and had the mush just close up behind me and stay clogged. One I could not believe my eyes when I opened a downstream cleanout and it's clear and there is my cable and its still clogged. I went back and forth thru that one 4 times grinding it up before it finally let go.
              Thanks ,I'm starting to get this drain clearing
                If you had broken something they would have expected you to pay for it.
