which nozzle to use
  • which nozzle to use
    which is the best nozzle to use when jetting a main at a resturant with lots of grease.
    Re: which nozzle to use
    warthog is the best, but need your jetter specs and the line size to really know what will work for you.
      thanks but not real sure , the people that I am helping have a 4000 psi gas but not sure of gpm but it only runs from garden hose so I am really not sure what you can get from that, thanks
        4000 psi is good. i would assume it's at least 4gpm as it's a gas unit.
        depending on your budget, a 3/8''warthog will set you back at least $700.
        a regular stainless nozzle with rear jets will set you back $35.00.
        still need to know gpm, hose size and pipe size.
          rick you are right it is 4 gpm
          and I think 3/8 also have 1/4 hose
          some 4" and some 6" pipe.
          which size should be used for that size jetter. it seems when the larger hose is used it is hard to really get the hose go past 150 if there is any turns
            Can you pull back from a main hole? I have some PM that the main can be done from outside. A Bullet style with most of the jets on the back, spraying the pipe clean and pulling it to the main hole. When you get it open running water with a smaller jetter works to flush the line clean. I dont any cables since we got are 20 gpm system.
              thanks that is what I did the other night the city cleaned the main so I was able to go from out to in and pull back that worked great , cleanest the line has looked in a long time
                Talk to Neil at Aqua Mole he knows his stuff about jetters and nozzles. they will custom build nozzles to the job you want and your jetter
                Mike
                www.plumbinginclarkcounty.com
                  thanks
