oil cable Page Title Module
  • oil cable
    what can i use to lube my cables
    Re: oil cable
    I use 'Snake Oil' from General about once a year or if they are stinking up the van from a particularly stinky job.
      Re: oil cable
      The best in the world. http://www.astroglide.com
        Re: oil cable
        I use Ridgid's cable oil - it really stinks in an enclosed area. :-)
          Re: oil cable
          I use snake oil from general as well.I have tried the ridgid oil before but really didnt like it.The ridgid oil is very thin about like water while the general snake oil is thicker like oil.
            Re: oil cable
            I dont remember if it was on this forum or over at PZ, someone suggested using Marvel Mystery oil (engine treatment) to lube cables. I have tried it and it seems to work fine. I find it has a wintergreen kind of smell.
              Re: oil cable
              I use my cables daily, it would be a waste of time and oil, to lube them up.
              I guess you could say I lube my cables with cooking oil, animal fat, ground food particles, soap scum, poo, pee, spit, vomit, etc.
              Lenny
              Pronounced A-Bear Drain Care
              I know, it doesn't make sense.
              http://www.hebertdraincare.com
                Re: oil cable
                Hi there cajun, I'm a 1/2 cajun in the new orleans area.
                Lenny
                  Re: oil cable
                  All the more reason to lube them.Lubes made for cables have a rust fighter and more importantly an acid neutralizer.We know cables dont care much for acid drain cleaner chemicals.
                    Re: oil cable
                    Three of my cables are in open reels so they drip dry and dont get a chance to rust.
                    My smallest cable 1/4 inch is in an enclosed reel and rusts quickly if I dont spray the inside of the reel with wd40. I think its because it cant drip dry. I do pull the cable out with paper towels, but its still wet.
                    When I run a line that I know has acid in it I make sure to flush the cable well.
                    This works well for me.
                    I cant see putting oil on my cables adding that much more life to be worth the extra time it takes to add the oil.
                    I can make enough money in one day to replace all of my cables that will last one to two years and make me six figures.
                    If I had all enclosed reels, I would probably have a different opinion.
                    Lenny
                      Re: oil cable
                      i'll spray mine with WD-40 to help inhibit rust a bit, but especially to keep the link pins from freezing up. LPS would be a better choice but WD-40 is a heck of a lot cheaper.
                      steve
                        Re: oil cable
                        on my k39/ 5/16'' cable, i remove them from the drum and store them outside the drum.
                        the rest are sectional that get washed off as needed and i oil the spring loaded pins with wd40.
                        when i was runnig drums. i would use ridgid snake oil, general oil, atf fluid, even diesel fuel.
                          Re: oil cable
                          Same here. BUT, even if they did sit for for any length of time, I wouldn't bother. My 1/2" cable is 10 years old. I don't use it much. In that time it's seen maybe 200 jobs, chemicals, grease you name it. Still no need to oil. I've tried all different types lubes and have not noticed any prolonged cable life.
                          The only reason I think cable would need oiling is due to low quality wire or not being rinsed thoroughly after running it through a chemical line and then letting it sit.
                            Re: oil cable
                            You got Me Sucker!
