Anybody ever use CLR?
  • Anybody ever use CLR?
    it stands for "calcium-lime-rust".
    the reason i ask is i'm wondering if it would work on urinals?
    Vince
    Re: Anybody ever use CLR?
    Works well:-)
    If you can get a product called "Santeen" get it, it is better than CLR
    Okie
      Funny you should mention that Vince, I have just started using CLR on blocked aerators and shower heads , seems to work well.
      I haven't used it on urinals yet but would be interested to find out too.
      Simon
        I use Calci-Solv on urinals after snaking them, sometimes you will have to re snake the drain after the Calci-Solv.
          Calsi-solve or muriatic acid for cleaning urnals. The CLR might work if you have all day.
            Vince
            Its the greatest stuff for cleaning shower screens at home.
            Tony
              Tony
              That's a strong admission on this forum to imply that you clean your shower screens
              Simon
                I had a rash of urinals last week,most Am.Stand. with these tiny trap ways.
                I run the 1/4" cable through them then follow up with the Santeen.
                It is produced in Hopkins MN (SW side of the cities,here) and they distribute to mostly
                Hardware stores.
                Atwoods Supply, OK
                A. Y. McDonald Supply, IA
                Barrett Hardware
                Coast to Coast Hardware
                Country General
                Dakota Wholesale, SD
                Hance Hardware
                J. H. Larson Plumbing & Elec. Supply
                Kuesters
                Plumb Plumbing Supply, IA
                Trust Worthy Hardware
                Wigman Plumbing Supply, IA
                WinterBottom Plumbing Supply, IA
                1321 7th. St. So. Hopkins, MN 55343
                (952)935-4500 Fax (952)935-3146
                  Sizzle or calci solv.
                  I recommend CLR to maintain the urinals. Let it sit overnight once a month
                    Simon
                    Well CLR is strong stuff Simon
                    Tony
                      Tony
                      usually by the time they call the plumber the trap is almost if not completely sealed. Too much for CLR to break down quickly. The other products mentioned are much much stronger and can dissolve the build up in a half hour or so.
