Cable snapped
  • Cable snapped
    I have a 3/4 inner core cable that snapped on my K-750.
    About 8 ft snapped off .Is there any way to put the head coupling back on.
    Thanks
    Ray
    Re: Cable snapped
    order a new female coupling. approx. $20.00
    cut it off clean and screw the end onto the cable. tack weld into place.
    probably better off taking it into the repair shop as it sounds like you havn't done this before. the welding process is critical.
      Re: Cable snapped
      Thanks Rick
      You are right I have not done it before.
      Where do I buy the coupling?
      Ray
        Re: Cable snapped
        either a plumbing supply house, or better yet a service center for your machine that can do it for you.
        lets see if ace sewer/ alex can jump in as he's in your town and should know a shop in the area
        they are easy to install, but tricky to properly tack weld if you've never seen it done.
        too much heat and the cable can become weak.
          Re: Cable snapped
          yes, grind off the weld and remove the coupler end,
          or buy a new one,
          http://www.ridgid.com/Tools/K7500-Dr...e/EN/index.htm
          Cat. No. Model No. Description
          31487 .... A-7570 .... 5/8" Repair Splicer
          92805 .... A-6582 .... 5/8" Male Coupling
          92810 .... A-6583 .... 5/8" Female Coupling
          31492 .... A-7571 .... 3/4" Repair Splicer
          92880 .... B-6840 .... 3/4" Male Coupling
          92885 .... B-6841 .... 3/4" Female Coupling
          cut the cable off clean (I find a cut off on a small grinder works well), pull a little of the inner core out a little and cut it off so it is a tad shorter, and let it back in, screw in the coupler end, and spot weld it.
          here is a how to sheet from Spartan
          http://www.spartantool.com/pdf/sheet...stallation.pdf
            Re: Cable snapped
            What is the best repair?
            Should I loose the 8 feet and get a female end or get a coupling/splicer and put that in and have both sides welded.
              Re: Cable snapped
              8' is nothing. lose the 8' and install a new female end.
                Re: Cable snapped
                And tell Mrs. Haggerty "some idiot broke a cable in Your sewer, I'll do My best to retrieve
                It next week , not to worry". Now You didn't fibb! She doesn't have to Know ALL the details !
                  Re: Cable snapped
                  I got it out .
                    Re: Cable snapped
                    Well, you only paid $400 for it and the machine right? Buy a new cable so you don't get bit by this unknown used one again.
                      Re: Cable snapped
                      Originally posted by onezee20 View Post
                      I got it out .
                      Sure You did , We'll just call the haggertys to make sure!
                        Re: Cable snapped
                        Which is why I prefer hollow core.
                        a splicer, two vice grips, loc-tite, 3lb maul, 5 minutes later you're back in business.
                          Re: Cable snapped
                          The whole point of innercore is that they kink less, and break less since they can handle more torque. So you end up having less repairs to do.
                            Re: Cable snapped
                            I worked with inner core cables for two years, and found that they flipped, kinked, snapped just like the hollow core cables.
                            I also found that they're not as easy to fix when the inevitable happens.
                            Whether they last longer or not is irrelevant.
                            Let's say I get called to an emergency at a restaurant that is depending on me to unstop the bathrooms before they have to close and lose 10's of thousands of dollars on a Saturday night, but wait I need to go to my shop and tach weld this end on, or worse, bring it to the repair center on Monday morning.
                            With hollow core, I can have the cable fixed in 5 minutes.
                            I already keep extra reels of hollow core cable on my truck for extra long runs. (up to 300ft)
                            If I used inner core, a back up reel would be mandatory, IMO.
                              Re: Cable snapped
                              Thanks
                              Ray
                              So much for innercore not breaking.
                              I'm with you Herbert. Standard cable is a snap to splice. No welding necessary. Even though my cable comes from the manufacturer with ends welded on, I've never experienced the need to do so when it comes time to replace first 50'. Then again, I rarely kink or break my cables nowadays anyhow. When I was rookie, I went through cables, ends and splices like they were going out of style.
