my new score
  • my new score
    pressure to be main into a jetter
    18HP 5000 psi 5 GPM
    $200.00
    i would say 7 out of 10
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: my new score
    We used to rent those big v twin briggs motors. Good score for you keep the RPM's as low as possible to get the PSI you need.
    Seattle Drain Service
      Re: my new score
      Cool.
      Do you have a hose reel setup already on another pressure washer.
      Got pics?
      I have a 13hp 3000psi 5gm jet, and I think my 3/8 hose is only rated for 4000psi.
      Although my pressure has only been hitting 1800-2000 psi lately.
        Re: my new score
        pump is a genral TS2021N
        5.6 GPM
        3500 PSI
        Appleton WI, 54915
        1-920-284-7471
          Re: my new score
          5.6 GPM
          3500 PSI
          same pump i have on my 18 h.p. machine.
          there is no way to get 5 gpm @ 5000 from a 18hp. gas engine. math doesn't work.
            Re: my new score
            I was mistaken and had reposted the correct GPM and PSI
            5.6 GPM
            3500 PSI
            Appleton WI, 54915
            1-920-284-7471
              Re: my new score
              Nice.
              Good lookin' out.
                Re: my new score
                how do you do the math? i'm not putting my finger in your eye, but i don't understand. ace sewer posted a formula last year. hp = gpm x psi v .0005833. does that work? if not what is the formula? i know that is for a 100% efficient system, which in reality does not exist. do we have a huge power loss? i am planning on doing what appletondrain did, so i would like to know how to figure this out. thank you. breid
                  Re: my new score
                  I'm not sure Ace's formula takes pressure loss from the hose into consideration. I'm sure more than one person has been tripped up buying nozzles sized for their pump output vurses the output at the nozzle end of the hose...
                  Okie
                    Re: my new score
                    i believe those #'s are for an electric motor and not a gas engine.
                    the #'s that are realistic for gas is hp= gpm x psi / 1100.
                    so 5.6 x 3500 = 19,600
                    19,600/ 1100 =17.818 h.p
                    keep in mind that is the max h.p for an engine all out. doesn't take into account pressure loss from friction and h.p loss from altitude.
                    gas engines are approx 2/3 of an electric motor.
                      Re: my new score
                      it needs 13.4 EBHP Electric HP per specs
                      gas it needs 17 GPH gas HP
                      now this is for the best results
                      Appleton WI, 54915
                      1-920-284-7471
                        Re: my new score
                        or u can check out he link with specs
                        http://www.pwmall.com/website/Nprodu...2927&ID=125958
                        Appleton WI, 54915
                        1-920-284-7471
                          Re: my new score
                          Just some FYI.... Rick will go on forever that you cant have anything better then what he`s got
                            Re: my new score
                            is that what im reading ?
                            Appleton WI, 54915
                            1-920-284-7471
                              Re: my new score
                              pr. thank you. that is an optimal situation where everything has to be spot on. that ain't likely. printed that out. my other formula wasn't working. thank you. breid
