What's the difference in spiral saw bits?
  • What's the difference in spiral saw bits?
    The one I always see have teeth like a regular sawblade but I've seen others with half round cutouts instead of teeth. Any advantage to the latter?
    Re: What's the difference in spiral saw bits?
    Ben, when you say spiral saw are you talking about a Roto-Zip and similar tools?
      Spiral saw blades for draincleaning.
        Doh! Shudda looked at the forum area where you posted this "Drain Cleaning". Sorry.
          Ben, Got a picture of what you are talking about?
          I don't wanna run out to my truck and check my saws...
            It shows it in the catalog as T207-209.
              serrated cutters. my knives are like that. they will stay sharp longer, a lot longer. but they cut not rip and saw like the older style cutters (sawtooth t-107). your call. try one see if you like it. the half moons stay sharp. breid
                ben the t-207-209 are spiral bar cutters that fit the 5/8'' sectional cable along with the 3/8'' male coupling cables.
                they are very similar to the spiral sawtooth cutters except they have no real agressive teeth.
                they basically have a less aggressive notch in the cutter so it's gentiler on the machine and cable.
                they also make a bar cutter for the 1.25'' cable that's a t16-18.
                it's easy to cut notches into a worn spiral sawtooth cutter, but hard to cut teeth into them.
                spiral saws are much more aggressive.
                unless you're using it on a small cable or machine, stick with the more aggressive spiral sawtooth cutters like t-109-111 for 7/8'' cable.
