General super vee
  • General super vee
    I feel The supplied assortment lacking. Added a 2" blade set. Any thoughts?
    Re: General super vee
    possibly too big for that machine. use it on a 3/8'' cable only.
      pr is correct! i have a k-38 with general 5/16" x 50' cable and cutter set. where you going to use a 2" cutter? breid
        What comes with it won't scour a 2" pipe.
          tool the only way to really clean a 2'' pipe is with a jetter or a larger cable. the power vee or k39 is just going to poke at it.
          put a 5/8 or 7/8 sectional in there and the line will be spotless.
            I cut out a 1-1/2" old galvy lav drain just below the 1 st floor ceiling. 80% blocked.
            rodded it from roof vent. cleared but not scoured, I can see it. Was a good lesson for Me to actually eye ball after! Ifeel blades would cut the gunk better!
              old gal waste pipe is next to impossible to clean out the old rust deposits. even no hub and cast is difficult. but cast/ no hub takes a lot longer to get this condition.
              plastic and copper don't corrode. plastic is the easiest to clean and maintain. copper isn't as common and does clean, but not as easy as plastic.
              hand snakes were not designed to scour the pipes. the cable is too flexible. the largest cable you can run is 3/8'' in a portable hand snake. sure you can install a cutter, but do you really want to hold onto it to work the pipe clean? plastic, no problem. metallic no way.
                I need to dump the 1/2" cable on My K-375 and buy some more 3/8". That would be a better choice for this kind of application,right?
                  TRUE!
                    Holy crap, service guy you have got a crap load of ridgid drain cleaning tools.
                      Yea that pic looks like the Ridgid catalog lmao
                      Seattle Drain Service
