Cleaning a 4'' main from a 1.5'' c/o.
    Re: Cleaning a 4'' main from a 1.5'' c/o.
    Good going Rick, tool guys "improvise" when it's time. Sometimes the bear eats you, sometimes you eat the bear .
    What would it cost them for you put in the correct size c/o ?
      about 4 hours of work under the house and stubbing to the outside.
      since i have a track record, and the line has lasted on average over 24 months, i doubt there is any reason to pursue it.
        does anyone here pull the toilet and run a cable through the house main when a suitable outside clean-out isn't available?
          all the time! lol
          Seattle Drain Service
            Excuse the ignorance, but I cannot figure out the reasoning behind a "reverse auger" at all.
            A regular cable wound the regular way will do the same thing won't it?
              Most every day. Some prefer the roof vent. I find 4" vents rare, and single story buildings with not-steep roofs without snow on them even more rare around here, so I prefer to pull the toilet.
                I have to hand to you guys that do this work in snow and ice. I lived in Colorado for a while. No way, NO FRIKKIN way could I do this work in those conditions.
                • #23
                  Code here calls for minimum 3 inch sewer vents so in the two largest parishes everyone has at least that. Some nearby parishes only have 2 inch vents. I dont get on two story roofs. Usually spend 5 minutes or so probing for a cleanout, then will jump on the one story roof. No cleanout, no vent access, I will pull commode.
                  If the bathroom is too pretty or the HO is too particular I will run from a 2 inch cleanout with a whip attachment. Running twice with a lot of water.
                  • #24
                    no it won't
                    the regular cable will only corkscrew/bite if it's run in a reverse direction.
                    the normal auger is too weak at the welded joint and i broke off 4 in 1 day on a job.
                    with the cable i use, i've never broken it. to corkscrew, you have to run in reverse. never had an issue and it my go to cable/ cutter when there is no other choice.
                    • #25
                      here we have 1.5 and 2 inch roof vents, unless it's an apartment 3 and 4 inch vents are a thing of the past. We pull a lot of toilets.
                      • #26
                        We have 3" and 4" vents but I refuse to go on roofs. Typically I'll install a cleanout where posible, or refer them to my local plumber if the toilet has to be lifted.
                        www.ClinkscalesSeptic.com
                        • #27
                          You have to have the same size vent as lateral [ side sewer back East] on the U.P.C.,
                          I thought ! Do people have less than a 4" lateral on single family homes in this country?
                          Do some homes have a 2" vent as their largest?
                          • #28
                            tool, out here pre 1959 was always a 4'' vent for the toilet to match the 4'' main.
                            after 1959, vents could be reduced to 2''. when i find a 4'' vent, i know it's old and typically a straight shot down the wall.
                            2'' can be an issue with vent 90's
