Rothenberger Innercore Sectional Cable
  • Rothenberger Innercore Sectional Cable
    Re: Rothenberger Innercore Sectional Cable
    I would like to here your thoughts on each brand cable.
      ben, is it similar to the 7/8'' with the same ridgid 7/8'' snap connectors?
      is it a plastic core or a wire core?
      can you post a photo
        Could be like this.
        http://www.toolsdirect.com/index.cfm...LAID=203639205
        http://www.mytoolstore.com/roth/pipe05.html
          looks like a very similar ridgid c-10inner core cable. the difference is the triangular wire they make the cable from. this is what gives the cleaning/ scraping action.
          the price is higher than the ridgid or the general innercore.
                That's some great, useful info thanks.
                  I like the General IC for it's ability to sustain a huge amount of pull.
                  I have used a come along to remove a stuck cable with no damage to the cable.
                  I even attached 2 old cables to a tree and my truck to see just how much the cable can withstand. I filmed it to post here but decided against it due to my Mainer hick accent.
                  Anyway I was able to pull it,I'm guessing 6'. At that distance the cable was starting to stretch and slightly deform when returned to slack position. Actually the cable returned itself back to slack position. When I let off the gas, the cable pulled me back like I was in reverse.
                  I then wentt slowly to about 10', and in 4X4 my plow truck just spun because of the snow. I then got running start and same thing. I finally had to get a good running start and come on to it pretty good before the cable finally snapped.
                  Result: 1 male end and 1 female end pulled/snapped out and one cable broke 1' from the end.
                  It was an amazing amount of pull that any cable would never see in the field, but it was a testament of how strong this cable is.
                  I wonder how much pull the plastic core can withstand?
                      I'd love to see it.
                      YEAH RIGHT!!!!
                      You've talked to me on the phone, you just want everybody else to hear my back woods accent.
                        Are you kidding,
                        You've obviously never sat down to a meal with the bunch of us.
                        You'd more than likely be seen as the one closest to normal.
