Testing the sewer service
  • Testing the sewer service
    up here i deal a lot with frozen sewer services.
    testing is pretty straight forward.
    dump a lot of hot water and flush the WC many, many times and watch for burping.
    if the customer doesn`t want the line camera`d, how far do you go with testing before you feel comfortable with the clearing you just did.
    Vince
    some how i got this little french ` thing happening and when i hit the question mark key i get this É. or this é. gotta figure this out.
    Re: Testing the sewer service
    I've never really timed it but i'm guessing I run as many fixtures as I can for about 10mins. I also flush 10 or so times at the same time.
    Even with all that, a small amount of ice will sometimes remain.
    I also encourage the HO to continue to use as much water as they can ie; take an extra long shower when I leave, do the dishes, laundry.
      One of the first things I do when arriving at a customer's house is filling the sink, bathtub and washing machine for a mainline or just one of them for a secondary drain. Once I get done snaking the line, open everything up and see if anything sounds or looks off.
        I roll up a ball of TP and flush it to see if it gets hung up, followed by several toilet flushes while giving it the listen.
        Seattle Drain Service
          Ice? What the hell is that? Why would you flush perfectly good ice? Beyond me..
            Sorry, Vince. That's a programmer's mistake and it's only supposed to be activated in Canada. It's actually pronounced "Eh?" and comes after every question.
              Good one, Herk
              When seconds count, the police are only minutes away.
                i got a nasty habit of setting myself up then walking right into it.
                that was a good one.
                Vinceh
                  well, doing frozens Im either working up the system from a cleanout or septic tank, in which case I get a major gush of dirty water when it lets go, or I'm working down from the building, in which case the toilet flange or whatever stops filling up with my jetter water when I get through it. I always finish with a large diameter nozzle to make sure I haven't just popped a hole in the ice and left a ton in there.
