K-7500 Drum Repair
  • K-7500 Drum Repair
    Hi Guys, I'm trying to rebuild a 7500 and I can't seem to get the guide arm
    off the drum. What am I missing? I have the first big lug nut off (the one with the hex allan key on it). And thats as far as I can see to whats holding it in there. Is there a hidden c ring or something????
    Re: K-7500 Drum Repair
    if i recall there is nothing else i had a pain with it the first time i tried. just pry on it it will come
    Mike
    www.plumbinginclarkcounty.com
      see page #2
      http://www.ridgid.com/ASSETS/A745F0F...Machine_PL.pdf
      once you have the knurled knob off, the guide tube should just tap off. the bearing is behind it and it doesn't need to be removed.
        Don't feel bad I had trouble finding the end of a broken cable and figured I would take our drum apart to make it easier. After 20 minutes I gave up and used our micro explorer to find the end. I was unable to get the shaft to move after using a few blocks of wood and a large hammer.
          Did you try some lube?
            Hey thanks guys! I had my helper 220lbs stand on the drum and I put
            a crow bar under the arm and I bounced on it until the crow bar bent.
            Couldn't believe it didn't come off. Hung my crow bar up and just for
            laughs I grabbed the arm by hand and it wiggled off. Man, that took about
            4 man hours in the last 2 weeks piddling around with it. But its off now so I can get the twisted cable out finally. I thought there has to be one of those C rings or something, but there isn't :P
