A new one for me.
  • A new one for me.
    A new one for me.
    I was called out on a service call Friday. It was a local pool installer.
    The installer was pressure testing the piping filtration system. It is all 4” high pressure pipe. He didn’t have a 4” test bag, instead he used a 3”. Well needless to say once he turned on the pumps the 3” test bag was suck into the system. I had to run 215 foot of cable to get the test bag out. the whole system was 90 degree bends so jetting it out would not work.
    Here are some pics taken with my cell phone.
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
    Re: A new one for me.
    Nice work getting that thing out. What machine did you use and cutter assembly?
      215' through a bunch of tight bends?! 1/2" cable?
        I used one K750 not enough cable so I grabbed my other one and dropped an additional 100’ more linked together with a retrieve on the end.
        Appleton WI, 54915
        1-920-284-7471
        • itsjosh33
          itsjosh33 commented
          Editing a comment
          How did you add more cable to your k750? Let's say I have 3/4"x100' in a line and need more cable. Do you use a whole other drum?
        I was able to run ¾” all new 4” pipe, under normal circumstances I would have not done this but it was new pipe and no breaks or question on the pipe itself.
        It was high pressure schedule 40 pipe
        It ran like a dream, but I did have a flexible leader on the end to make the 90s, the retriever helped as well. Once I felt a really hard spot I pretty much knew I had the test plug or a drain cover LOL
        Appleton WI, 54915
        1-920-284-7471
          Nice Catch! Love when things work out like that.
            It was kind of nice to clean my cables with pool water. “no shock yet”
            Appleton WI, 54915
            1-920-284-7471
              Whats with that last pic, is that the guy passed out by the pool after he got your bill and realized how much a 1" difference can cost?
                it was a pic of the 2 drains for the pool I walked to and found out the water was higher then my boots
                Appleton WI, 54915
                1-920-284-7471
