Small homemade portable jetter
  • Small homemade portable jetter
    I have a few accounts that require a higher power unit but in a small portable package.
    Here it is
    Under constructing yet
    Brigs industrial 18 HP engine
    General TS2021N Pump
    100’ 3/8 none marking pressure washer hose
    200’ ¼ Suttner jetter hose
    Suttner safety foot valve
    I did a pressure test suggested by RICK and others
    At the pump running 4000 PSI
    At the end of the ¼ hose running around 3000 PSI
    So for all of you who get tips, you need to see what your GPM and PSI is at the end of your jetter hose.
    Please keep in mind this is a work in progress
    Sent From The StoolBus
    www.appletondrainandsewer.com
    Appleton WI, 54915
    1-920-284-7471
      Re: Small homemade portable jetter
      5.5 max GPM
      around $800.00 most of its in the hoses and foot valve and hose reel
      Appleton WI, 54915
      1-920-284-7471
        Looking good. Keep us posted. I like to see your final result.
          hi there
          what will be your main jobs with this machine??sewer lines?
          can you do 2" kitchen lines in condos?
          thanks
            I can do 2” lines with a smaller electric jetter.
            I made this unit for 3-6” lines
            Appleton WI, 54915
            1-920-284-7471
              I made this unit for 3-6” lines in hard to reach places IE allies, back yards and any other area I can drive my truck in or out of easily.
              Appleton WI, 54915
              1-920-284-7471
                How much was for the engine , and how much for the pump?
                Can you post the prices for each part?
                  It looks like he bought a used Pressure Washer not new single parts.
                  But a 18hp motor around $1200 and a 5 gpm pump $500-800
                  Seattle Drain Service
                    That says a lot about YOU. That can do spirit , Is what makes this country Great!
                    Anyone can go out and Buy one. Good Luck Tool
                      i cnat rember what i paid for the Pressure washer? i think $150 -$225?
                      Appleton WI, 54915
                      1-920-284-7471
