what do you think of this?
  • what do you think of this?
    I'm going to buy a water jetter and camera. What do you guys think?
    GX390 HONDA POWERED JETTER/PRESSURE WASHER AND COMPLETE SEWER VIDEO MACHINE PACKAGE
    4000psi Jetter / Pressure Washer Combo Unit
    Includes C
    omplete Accessory Kit
    Works In - 2" TO 8" Pipe
    Sewer & Pressure Washer Accessories Included:
    Honda GX390 Commercial Quality OHV
    Air-cooled, 4-Stroke, Single Cylinder Engine
    Low Oil Automatic Shut Down
    Adjustable Pressure
    Aluminum Cart
    Intergrated Unloader valve
    Five Foot Jumper Hose
    Deluxe Jetter Hose Reel with Stand
    150ft 1/4" Low Friction Sewer Hose
    50ft Pressure Washer Hose
    Pressure Washer Gun / Wand
    General Brand - Direct Drive Pump
    Ball Valve Water Flow Operation
    1/4" Ram Sewer Nozzle
    1/4" Laser Sewer Nozzle
    1/4" Rotating Sewer Nozzle
    Five Pressure Washer Q.C. Tips
    Chemical Injector
    Designed To Clean 2" to 8" Lines
    PUSH CABLE VIDEO SYSTEM
    1 1/8 Inch Aluminum Head Camera
    70 ft. Deluxe 9/32” Push Cable
    16 Inch Reel
    Model Number #3-70-QV16
    WORKS IN 2” TO 6" PIPES
    SYSTEM INCLUDES
    • 8” Flat Screen Color Monitor In Aluminum Case
    • Real Time Viewing Only, No Recording
    • High Quality Color Camera
    • 1-1/8 Inch Diameter Camera Head
    • Produces The Best Color Picture
    • Aluminum Camera Body With Sapphire Lens
    • Camera Head Is Waterproof To 500ft
    • 10 White LED Lights
    • 11” Steel Spring Leader
    • 70ft X 9/32” Super Slick Push Cable
    • Pre-Wired For Induction Pipe Finder
    • 16 Inch Storage Reel
    • Operates On, 120 Volt Electricity
    • One Year Mfg. Limited Warranty
    • Ships In 4-7 Days – Via UPS Ground
    Re: what do you think of this?
    The info is FLUFFY
    I could care less about most of those bullet's.
    Get a plumber with jetter knowledge to help you and then you'll have better luck with what appears to me to be your attempt at spam.
      i'll respond to the jetter and let others jump in on the camera
      13 h.p honda at 4000# is high pressure, but not high volume.
      i would go with a higher volume and drop the pressure to 3000/3500.
      most 13 h.p at this range pump out 4gpm.
      gpm is more critical than psi at this range.
      didn't see a foot valve, only a reel valve
      direct connection pump is not a long life set up. runs hot and high rpm's.
      belt drive is the best or gear reduced is next.
      not sure what you're paying, but i would shop around for better specs.
      all they did was put together a pressure washer and add some jetter hose and nozzles. without a foot valve or pulsation, you'll have a fun time making tight turns. the spray gun can be used as a foot valve, but a foot valve frees up 2 hands for easier operation.
      now the camera is another thing
        70’ seems kind of shot for the camera? IMHO
        Sent From The StoolBus
        www.appletondrainandsewer.com
        Appleton WI, 54915
        1-920-284-7471
          Seen this joke of a set up for sale on ebay all the time. I have to agree tihs is a poor attempt at spam.
