urnial
  • urnial
    best way to clean a urnial and do you charge more for such work
    Re: urnial
    If it has an integral trap, pull it off the wall. If it has a removable P-trap under it remove the P-trap. Once you gained access to the pipe the power rod the line, then ensure the urinal itself is clean, rehang the urinal or replace the p-trap, test flush and look for leaks.
    The only more would be a new seal for the wall hung integral trap urinal.
      Re: urnial
      thanks I just did not like to remove wall hung urnials because it seems I have a hard time with leaks. Most of the jobs I do are just clean out caps and pipes below the sink
        Re: urnial
        Just make sure you have a new urinal seal, new o-ring for the Sloan valve supply pipe and you should be all set.
          Re: urnial
          I guess I am just going to have to get it and have those parts on hand.
          Thanks
            Re: urnial
            Muriatic acid......but that cheese turns to stone in that piping. It'll get it flowing though.
              Re: urnial
              Will that damage the seal to the flange?
                Re: urnial
                You mean the rubber on the spud? Nope!
                  Re: urnial
                  how long does it take for the acid to work
                    Re: urnial
                    well, I meant the rubber or wax ring holding it to the waste outlet. Is that the spud?
                    I've only installed/worked on a handful of urinals.
                      Re: urnial
                      I have always called that brass flange a urinal spud. Ron gave good advice about the flushometer tailpiece o-ring. That's a key one right there. I usually pull urinals, back rod them, clean any "sugar" out of the drain line and re-hang them. I figure 1.5 hours per urinal.
                        Re: urnial
                        My turn signal has a few dozen of them o rings on it. I hate it when I work on a Sloan valve and not having a replacement o ring.
                          Re: urnial
                          Just last friday I was contemplating this exact idea! My Best Plumbing salesman sells urinal cleaner that is Hydrochloric acid. Researching this, I found Muriatic acid is another name for it. I have 2 gallons of Muriatic sold as RV cleaner. But, I don't know the mix rate? I fugured to pour a quart in and let it set over the weekend, then flush it. How does that sound?
                          I've got 50 urinals on campus, something needs to work.
                          God Bless You Super Good!!!
                            Re: urnial
                            If you want to use a chemical go for some Calci-Solve Stuff works great. I also use it in tank type water closets. Pour a quart down the overflow tube and let it sit for 10 minutes. The water closet will flush like brand new. http://www.nycoproducts.com/products.asp?pid=79
                              Re: urnial
                              i know what you mean.
                              try this; before you remove the fixture, mark the wall and the bottom of the urinal with a pencil or marker. this will help when re-installing.
                              Vince
                              i like to coat the new gasket with some wax. sticks to the spud really good eh.
